When i go to BBC HD channel i get the sound but no picture, all the other HD channels are fine but not the beeb ones.
Anybody know why this could be?
Sorry forgot to mention Chud, i'm using Sky HD !chudleighpaul said:Are you using Sky, Freeview or Freesat?
Hi daveh75daveh75 said:Have you tried powering down/rebooting the box?
ok i will try it, i'm recording something at the moment so shall i wait until it's finished before i do it dave?daveh75 said:They're both working fine on my boxes so isn't a broadcast issue. Try a planner rebuild if you haven't already.
To do a planner rebuild,
On the remote, press "Services" followed by 0-0-1 in quick succession (which get's you into the installer menu)
Then scroll down to "Planner rebuild" and press enter or press 7 then enter. (Don't worry a planner rebuild won't delete recordings)
Ok thanks, i'll do it shortlydaveh75 said:Yep, wait till your recordings finished.
