- Aug 10, 2019
- 2,556
- 5
- 0
Hello All,
I have recently bought the Onkoy 605 receiver and am in the process of trying to connect it to my speakers. I have purchased the QED Silver Anniversary XT speaker cable terminated with banana plugs based on the What Hi Fi advice.
This is the first time I have used a speaker cable that is terminated in banana plugs and I find myself unable to connect it to the Onkyo receiver. The width of the banana plugs is too big for the connection points on the receiver.
Are there different banana plug sizes or something? Needless to say I am quite upset about forking out the extra cash for the banana plug terminations when it appears that the receiver will only accept bare wire. The receiver manual states that it accepts banana plugs, but I believe this to be incorrect.
Has anyone connected the QED Silver Anniversary XT speaker cables with banana plugs into the Onkyo 605's? How are you connecting your speakers to the receiver if not using banana plugs? Any advice would be appreciated.
Thanks,
James
Thanks,
James
