OK, long overdue update and I've forgotten the associated narrative I was planning to use to support the photos. Still, here goes.....
I bought a shed load of 4x2 planned timber and some 1/4" plywood from B&Q. What I needed to do was cut all the 4x2 to length and join all the 4x2 together to form the sides, top and shelves. I wanted a strong joint, so decided to route a small slot in the side of each length of 4x2 and use the a 1/4" plywood fillet to strengthen the joint.
Routing the lengths of 4x2 to introduce the slot for the fillet.
A part glued shelf showing the plywood strengthening fillet. The fillets were ripped down from a sheet of plywood using a bandsaw.
The slotted 4x2 complete with plywood fillets then needed to be glued and clamped. I glued three lengths together at a time, slowly building up the sides, top and shelves. I used Bessey clamps....expensive but just about the best you can get. You need a lot of clamps!
I then routed the sides to accept the shelves and the top to accept the sides (not shown).
I then routed a further slot to fit in a plywood fillet to strenghten the joint between the sides and the shelves and the sides and the top (not shown).
I then glued the sides, shelves and top together and sanded the whole lot down. If you're in the market for a orbital sanded I can highly recommend the
metabo duo and DM Tools as a supplier of all DIY tools.
Next was the finishing. I agonised over this. In my experience, this is where it all goes wrong. I finally went for this stuff.
I then applied the finshing products to the stand, giving it a couple of coats and then giving it a good polish and that's the finished stand!
This thing is immensely strong and heavier than the average stand. The stats are...
ComponentLength of 4x2 (mm)Estimated Weight (Kg)
Top82608.26
Sides75767.58
Shelves1218012.18
Total2801628.02
Note: I estimated the weight by weighing a short length of 4x2 and established that the timber weighs approximately 1g per mm.
I have to say I am quite pleased with the results but it was a fair amount of work. It ended up costing about a ton.
Not sure I like the colour much. It's supposed to be light oak but it has the inevitable orangey look about it. Still, this is a temporary stand.
In the near future, now that I have validated the design, I will use oak kitchen worktops instead. Expensive, but I won't have to fabricate the board.
