Womaz said:I was blocked by Mods last night....no idea what that was about!
DocG said:Womaz said:I was blocked by Mods last night....no idea what that was about!
What? Have the mods come alive again?
Womaz said:I really wish you could see what forum members systems are. For eg the Devialet users. What do they use as their source.
DocG said:Womaz said:I really wish you could see what forum members systems are. For eg the Devialet users. What do they use as their source.
I have a Devialet 120 driving (SAM-enabled) LS50s. I used a Sonos Connect and a Rotel CDP as sources, which I recently replaced with a NAD M50. The M50 is a streamer, with BlueSound multiroom functionality, and with Spotify Connect, and it's also a CDP and a CD-ripper. I can (and do) use all those functions. The M50 has no DAC (so I'm not paying for a DAC-section I won't use). It's connected through a Power-LAN at the moment: not ideal, but will change to UTP in the new house. IMO, the BluOS user interface is on par with the Sonos UI.
So I'm pretty happy with the current combo. The significant discount helped me decide too, to be frank. *ok*
Womaz said:.....I am thinking 4.5k outlay on a source will blow my mind. For that sort of money thats what it needs to do.
After yesterday I am not sure it will do that. Cno you mentioned subtle differences. TBH for an outlay of 4.5k I want more than that.....
gowiththeflow said:Womaz said:.....I am thinking 4.5k outlay on a source will blow my mind. For that sort of money thats what it needs to do.
Most, if any of the subtle differences probably won't be coming from the streaming aspect of the device. It might be more worthwhile to bypass the DAC in the MF CLIC and use a good quality external DAC. Not only would this save a significant amount of money, it might actually render audible results equal to or superior to those obtained with the ADS.
Example - the highly rated Hegel H12 @ £900 or the (very much high end) Auralic Vega @ £2890. There are other well regarded contenders in the marketplace.
DocG said:.....The M50 is a streamer, with BlueSound multiroom functionality, and with Spotify Connect, and it's also a CDP and a CD-ripper. I can (and do) use all those functions. The M50 has no DAC (so I'm not paying for a DAC-section I won't use). It's connected through a Power-LAN at the moment: not ideal, but will change to UTP in the new house. IMO, the BluOS user interface is on par with the Sonos UI......
Womaz said:Yes I considered this too, a better DAC, but unfortunatley the CLIC does not have the outputs to do that.
Womaz said:DocG said:Womaz said:I really wish you could see what forum members systems are. For eg the Devialet users. What do they use as their source.
Thats excellent, thank you for sharing this. So the bulk of the cash is on the Devialet I guess.
gowiththeflow said:Womaz said:Yes I considered this too, a better DAC, but unfortunatley the CLIC does not have the outputs to do that.
Apologies. I thought I remembered, more likely assumed, it had a digital out. I just checked and you're absolutely correct.
Scrub that idea; but you can see where I was coming from.
DocG said:Womaz said:DocG said:Womaz said:I really wish you could see what forum members systems are. For eg the Devialet users. What do they use as their source.
Yes, bulk of the cash for bulk of the functionality: some 2/3 of the total budget, but then again, it's a DAC + integrated amp + its effect on the speaker performance is substantial too. I'm not using the AIR streaming function myself (not reliable enough in our current situation, with WiFi and PowerLANs), but that's also included in the package.
And the free upgrades are nice (extra power thru a firmware upgrade, the SAM protocols, and who knows what's on the horizon)!
CnoEvil said:I would certainly have empathy for your position, as I've been there and got the T-Shirt.
I have been treading a fine line between encouraging you to try stuff, while also advising caution/patience....though just for clarification, I need to explain my position on the Digital Source more clearly.
When I said the difference a source made was "subtle", it was in comparison to amps and speakers, where especially with the latter, the difference can immediately smack you across the face.
So when I say subtle, I don't mean it's not worthwhile, but that it can take a bit longer to assess the improvements. This can be very noticeable if you have lived with it for a few days and put back the old source. It is then not uncommon to find there is now something "missing", which drops your enjoyment and involvement down a few notches.
So to pick the bones out of what I am saying, I would advise the following.
- It is quite sensible to take your time, but don't stop your demoing of stuff ie. To see where the best balance of funds lies between Source and Amp.
- If your dealer has brands nearer to your own, try to get him to demonstrate the difference between Sneaky, MDS and ADS.
- Be straight with you dealer and ask him to help you find the correct path, and say a home dem is essential in this process.
- If you are going to live with your system for some time, it's essential that you discover the right amount (which may be nothing) to throw at it.
- Compare all in one Streamer / Clic + Dac / Devialet type solution (where the amp has an integrated DAC).
- The more actual demoing you do, the clearer things become....it helps wade through the well meaning, but ultimately confusing/conflicting advice you are getting from us lot, and so find where you ultimately stand on the matter.
iQ Speakers said:Sorry I have alot on, but started to skip through the thread, interesting, Linn same price as a Devilat wow. Having heard and seen the Dev, and knowing the scope of CPU based products, think Sonos, to stay current and flexible I would say thats an exeptionally good idea. I can see me buying one before long, it just seems to make sence, Just softening Mrs B up with all these boxes coming and going.
Womaz said:I am in the process of investigating the Devialet as a solution like that, less boxes, less £200 cables really does appeal.
I would love to hear a Devialet with my 23s and the 26s. All of this cant be purchased all at once, but it would give me a goal if you like, and if i dont replace the source now some of this is achievable in the next few months. Looks like i would have to travel to Edinburgh to do a demo though, so for me I cant keep doing demos. I would have to have a very definite shortlist and take it from there.
matt49 said:iQ Speakers said:Sorry I have alot on, but started to skip through the thread, interesting, Linn same price as a Devilat wow. Having heard and seen the Dev, and knowing the scope of CPU based products, think Sonos, to stay current and flexible I would say thats an exeptionally good idea. I can see me buying one before long, it just seems to make sence, Just softening Mrs B up with all these boxes coming and going.
This is where your friendly Devialet owner steps up to the mark. Sometime over the next month or two we should get together in Cheltenham or at our place near Stroud. I can bring my Devialet up from London for you to have a play with. Interested?
It might be worth signing up to Devialet Chat (the unofficial Dev owners' forum) and asking whether there are any owners near you on the Tyne. I'm not sure there are any, but no harm in trying.
Matt
iQ Speakers said:Interested!! Is the Po...... If we do it in Cheltenham I know a great bar, The Retreat for lunch, they also have one in Stroud though not a chain, so don't know if they do great food. Let me get the Abrahamsen working! And a set of competed speakers! Oh not to mention s decent source. Apart from that we're good to go.
Womaz said:Yes it all gets a bit confusing. I think your point about listening to a new product for a little while and then replacing the source is a good one and probably why my Linn dealer wants to give me a ADS for a weeks trail.
I am still keen to hear the ADS in my system.....not sure what response I would get if i asked for the sneaky and majik as well.
CnoEvil said:Womaz said:Yes it all gets a bit confusing. I think your point about listening to a new product for a little while and then replacing the source is a good one and probably why my Linn dealer wants to give me a ADS for a weeks trail.
This is why I suggested getting your dealer to demonstrate the difference in his shop, on a system closer to yours....who is the dealer and what brands do they stock?....can you give a link?
If your dealer will lend you an ADS for a week, then take them up on the offer and you will be a lot wiser (one way or the other).
