Audioquest FLX-SLip 14/4 Speaker Cable
Lo Fi
28
I am thinking of using the version of Audioquest cable that was given a best buy by What HiFi and wondered how it was wired.
Does anyone know for sure if it was 2 wires into each plug at each end and also which banana / Z plugs were used in the test.
Hopefully someone from What HiFi will respond soon.
For what it is worth if they used the cable photographed in the review section then it was fitted wth Audioquest's own SureFix bananas.
Cannot be sure if it was wired 2 into 2 or 2 into 4 though.
Lo Fi said:
tino1104 said:
I have mine wired 2 into 2 works a treat!
Assume you mean two wires into each plug, By the way which plugs are you using?
Yes two wires into each plug. I'm using Sewell silverback banana plugs at the amp and Sewell deadbolt spades at the speakers they work as well as anything i have tried before.
