Audio Erotica
MattSPL
19
Found these Krell Master Reference amplifiers for sale, 1000watts into 8ohm's, doubling all the way down to 0.5ohm's where 16,000watts(16KW) are available.
See the MRA Subwoofers in the background too
Just need to win the lotto then buy a power station to run them.
Escapism
I once saw something very similar at Guildford Audio (Krell or Audio Reseach, I forget.) They would easily heat a room, and supply ample seating. Bit of a bargain when you consider all the uses.. ;-)
Hmm, yes I think the last page of this doc suits my needs perfectly...
REMOVED: Please do not link to downloadable files
MattSPL
19
ffiish:
Hmm, yes I think the last page of this doc suits my needs perfectly...:
Here
Are you sur 43,000watts is enough?
ASK THE COMMUNITY
