ellisdj said:That's because it's predictable based on room dimension and it pretty much bang on. Have confidence in it.
The reason you can't fix it is because it's to do with the length of the room most probably.
Now try increasing the absorption option on both the front and back wall and watch that null dissappear.
Then also add 2 3 and 4 if necessary subs.
Move them around front and back corners etc.
Invert one or 2 etc and watch the impact it has on the bass response.
It's huge. Very interesting lesson to learn from that software. You can see why I always harp on about it
nugget2014 said:If my seating area isnt the null like i previously mentioned but others make certain frequencies peak then an antimode would possibly help get my frequency response more in line in my seat as i have a rise above 50hz?
£300 seems a bit expensive just for essentially an extra bit of EQ though.
bigboss said:nugget2014 said:If my seating area isnt the null like i previously mentioned but others make certain frequencies peak then an antimode would possibly help get my frequency response more in line in my seat as i have a rise above 50hz?
£200 here:
http://www.bkelec.com/hifi/Sub_Woofers/anti-mode-c.htm
You cant go exactly by those numbers as the spl metre your using wont be accurate and will require a calibration file to correct for its inaccusracy. All mics needs this generally.nugget2014 said:Is it a possibility that my left seat isnt actually much of a null but my middle and right seats are just getting peaks in the room?
I measured again before i was to turn the other sub on with its new position but these are the results i got playing at -20db
20hz 53db 25hz 56db 30hz 53db 35hz 56db 40hz 62db 45hz 66db 50hz 68db 55hz 68db 60hz 61.5db
What to make of these measurements?
ellisdj said:You cant go exactly by those numbers as the spl metre your using wont be accurate and will require a calibration file to correct for its inaccusracy. All mics needs this generally.nugget2014 said:Is it a possibility that my left seat isnt actually much of a null but my middle and right seats are just getting peaks in the room?
However its not bad in terms of consistency by those numbers but again its reducing the lower it goes, ideally it should be increasing.
