Are all CD players really equal?
👍I get your point, although on the contrary the CD 60 infact nestles in-between the CD 52 MK2 being the lowest at a standardised 2 V-rms and the CD 6007 having the highest output voltage 2.4 all within 0.2v of each other in a kinda tasty Marantz sandwich with the two budget players both new and old being the tiger bread at either end of a personal favourite mid-range filling of CD 60 😬
The subtle differences heard only between the CD 60 up against the other two, in which I didn't hear any precivable difference between the CD 52 MK2 and 6007 despite (maybe to some) a shocking 33yrs age difference IMO is predominantly because of the small differences "quality" DAC's make (and the already aforementioned opinions on my prior posts).
Owning these CD players further removes any other personal bias towards preferring either one when making comparisons.
I always keep to the same precieveable volume irrespective of the output voltage of any given ancilieries when swapping from
A-to-B in the interest of fairness, after all it would only be my time wasted by the same unconscious volume biasing that started "The volume wars" although worth noting that the volume needed no adjustment using the same CD.
You can still imagine differences purely through expecting there to be differences. You tend to focus on the music slightly differently each time, and if you're not doing instantaneous switching then I'm afraid out memory for sound just isnt that good when it comes to small differences or lack of.
Reactions: Dave_
However as per the other posts fully covering the non bias reasoning and fairness in testing culminating in the giving of my "opinion" and not feeling the need to defend myself, yet as I'm sure it's all in good fun so will further add-
It is indeed an "Instantaneous" switching A to B using the amp selection analogue 1 and 2 inputs via a Hegal H-190 which is as quick as your fingers can push.
(for the longevity of the amp I give a brief pause in the music before switching despite the amps automatic millisecond circuit muting)
As said I own the three CD players so there's no preconceived notions or bias involved only the listening for differences when I had a free afternoon, I even for lazies sake used a dual RCA splitter between the Marantz CD 60 and CD 52 MK2 but removed it after finding no difference between the CD 52 and 6007.
In the interest of fairness and because I'm over analytical to the point of causing me problems in life removed the RCA splitter and just went A to B with the 6007 and CD 52 for awhile hearing no difference at all, after a few instant switches between each not even knowing in all honesty which player was which, the Hegal remote automatically attunes to most ancilieries stopping the different remotes giving it away and the displays where facing away from me, the CD 6007 was removed and the CD 60 put in it's place, thinking it prudent and ever more interesting in the "spirit of thread" to put the oldest being the CD 52 MK2 (a highly acclaimed budget CD player in 1993) against a new CD 60 Mid-Range player, only then if listened for was there a subtle (but) undeniable difference.
The main thing to note is what's pertained to in my prior messages, I fully did not expect there to be much if indeed any difference between "Quality" players although did expect maybe the line voltage you eluded to might of needed volume matching which actually didn't.
I'm always swapping/demoing through kit regularly so in cases of cycling between amps and speakers the use of a Douk audio switcher was used for awhile but with amps and especially speakers the difference is instantaneously made that clear without the subtleties.
I've djayed both for fun and part time income since my early teens, living through what was for the masses a slow change from Vinyl to CD and then to Software in which I adhered only briefly myself, not to go off topic suffice to say I saw a highly skilled profession turn to an "anybody can do it software" I stayed with Vinyl and CD decks in which more to point 👉 I went through countless amounts of all makes and models in which a CD player was often used back then for the a backing track to be remixed over etc freeing up the 2 vinyl decks, up until my very late teens I only had limited gear so everything was done the proper/old fashioned way at first this was a Philips CD 604 then the very Marantz CD 52MK2 photoed (that's testament to the CD 52's quality) and all sorts in-between which would find there way to me as my father constantly upgraded whilst I grew up, in which they where mixed directly between, over and together and believe me everything in-between to be played through, thanks to my father as a kid growing up a constantly evolving hifi like my lowly to his setup.
With my Sansui au-502 then to become a mission Cyrus then pioneer a-400 with mission 760i and tannoy M15's so on and so forth I heard that little difference then and remember him having the same conundrum even back then.
As said sure there's definitely HUGE differences in sound quality with ultra cheap crap and bad CD players but IMO once a pinnacle of sorts is reached even with some budget CDP's then the gap closes immediately and only the DAC seems to me flavours things ever so subtlety.
Audiolab make several transports. It is not a brand usually associated with Audio B/S. Whilst I personally can't comment on any audible differences I would say there is a high likely hood they are there, however minute they may be. I use their 6000A.
They make them because there's a market for them!
Since the volumes wont be matched it's invalid. Also it isnt blind, making it invalid.
Reactions: Dave_
Nothing is worth comparing with anything else because they all sound identical....
Surely everyone understands this..... 🙂
No. It's just that blind testing is very important with things that measure so similarly. I've told you this before, AI ears. You never listen.
I beggining to think you've read NONE of my post now 😂
Short of quoting myself (and I haven't the time at the minute) I did all the above AND more than ticking every hurdle you seem to want to throw Infront of a clean test without bias .
I even used the Hegal remote to avoid identifying each player that way.
I see which camp you belong to now and hey that's fine, but do not agree with your not fully reading a post then commenting to the contrary of what it contains it's frustrating now.
It's all in good fun.
I will leave it their now the test was fair, more so because of the way I am personally but people who believe something else will always find fault.
This is starting to sound like the cable debate 🏃🏃🏃🏃🏃🏃🏃
Output voltages of the DACs, impedances of the amp inputs etc. But that's just one factor. If it's not done blind it's not proper either. These things measure so similarly from a frequency response point of view.
Dude read the posts.
It's making me 😬
Everything you say was more than covered yet your stuck reiterating meaningless things to a holistic blind test of a CD PLAYER against another CD PLAYER.
I bid you good morning I'm in a rush but the CDP wouldnt be being tested if they where altered in ANY WAY.
The things you mention now would indeed invalidate a clean test.
The amp was the same for a kick off with the same identical analogue input properties.
Again I circle you round to my prior messages which again tick all your boxes.
Just read it 😊
Level matching is only really relevant to quick A/B testing - if you're spending days or a week with a product, then swapping to another, precise level matching will be unimportant. We all have a comfortable listening level, and we'll find roughly that volume every time we listen, even if the amp doesn't have a volume display. I prefer to get a feel for what the amp does rather than A/B testing, which includes low level and high level, and higher, with certain albums and genres of music.
Some people's approach to HiFi is like tunnelled vision, it's not supposed to be an exact science. The reason why most people love this hobby is the subjectivity.
Measurements don't tell you what your own ears are hearing. Yes there is some who prefer to dwell on the psychoanalysis, placebo, confirmation bias, like they're giving out candy to distract from the primeval pleasures of listening to music.
Other hobbies like photography, there's a brotherhood or a collective spirit, yes a little ranting from brand loyalty but in the essence, people seem to love helping others with their experiences and techniques, to get the best out of photography.
Maybe it's me but HiFi has become so polarised, @Stuart83 is right "It's all in good fun", HiFi should be FUN!
It's making me 😬
Just read it 😊
It really wasn't covered. You didn't do proper blind testing.
Reactions: Dave_
It's for fun, to try out at home and see if there are any immediate quick differences. I'm all for measurements, but not in isolation and in any case, had a similar AB listening test with some new Hegel gear at Cranage at the weekend as the Auden Distribution guy swapped between the H400 amp and the new D50 DAC.
If you want to go down the prescribed blind testing route, be my guest - break out the Rhode and Schwarz gear, get someone in to switch between the different sources. And. So. On.
As for differences, yeah, of course there are. Sometimes they're minor, sometimes not. I can say that a simple listen to the Analogue Productions versions of Genesis' "Selling England by the Pound" and "The Lamb Lies Down on Broadway" SACDs show audible differences between my Cambridge 752BD and Pioneer PD-S505SP players. And this is using the CD layer (obviously, as the Pioneer is redbook CD only).
Yes, the are all 0's and they are all 1's but those values have to go through the dac and the electronics supporting the dac, and whatever company makes the CD play can warm up the sound or make it cooler.
Take the Marantz 6007 and the Arcam CD5, they both use the same ESS ES9018 DAC but they sound different. Marantz makes all their systems to be more on the warmer end of the scale, and the same goes with their CD players, whereas Arcam will be brighter sounding.
Difference for example is that when you hear a cymbal being struck on the Marantz it will ring and have a slower decay, whereas with the Arcam it will be more on the clang side of a ring with a faster decay. If you're into heavy metal the Arcam is the one to choose, but for older analog recorded classic rock, jazz, blues, etc, the Marantz will sound better.
But I'm just idiot with this sort of stuff.
As someone who has three current cd players I would say the Marantz CD6007 and Denon DCD900NE sound identical, while the Cambridge Audio AXC35 sounds nearly as good but not quite. Opinions will vary of course. I also have a 25 year old NAD cd player which when put through the Cambridge Audio DAC100 sounds just as good as the Marantz and the Denon. It seems to me that with most hifi these days you can't go too far wrong when choosing items from the major brands.
Marantz and Denon are from the same sister companies.
I suspect they share many of the same components.
