- Aug 10, 2019
- 2,556
- 5
- 0
After seeing a link to this from another thread I thought I would see if anyone else uses it.
It seems to provide a simple way to bypass your soundcard when using a PCM direct digital output no matter what audio player you use. This is good news for those who want to use WMP.
I'm guessing all audio from all programs goes through this (providing you select, 'force reclock to be loaded instead of default audio driver') including spotify!
It is the first time I have noticed an audible difference when changing settings for a digital output. Give it a try yourself if you are using a digital PC>DAC setup, and tell us what you think.
A quick Google will point you in the right direction.
