CnoEvil said:
I did a write up here: http://www.whathifi.com/forum/hi-fi/black-ravioli
I think it is very expensive, but can give good results. It is vital that you get a "demo pack" and try it in your system.
Valhalla Technology are worth looking out for as well, and much cheaper: http://www.kronosav.com/accessories/isolation.html
Wow Cno that's a really good write up! Thanks for that!
Unfortunately, I can't get a demo pack, i'll have to buy it straight... Is there any in particular you would recommend?
MakkaPakka said:
Why don't you connect the mac mini to a monitor, put some video or a still image on it then repeatedly nudge it and see if it has any effect on the picture quality. If it doesn't then you can reasonably assume the sound isn't going to be affected by small differences in the surface it's sitting on.
That's a good idea! I don't have a monitor though, I run it headless. However, I'm not sure audio through USB works the same way as video through HDMI, shouldn't the picture stability be more immune to nudging than audio? Audio I believe is more sensitive to vibrations??! I see where you're coming from though ... I will try it if I can
Stopsign said:
if you believe it will make your hifi sound better then it will. but why not believe that putting some cheap rubber underneath everything will make it all sound better and thus save a load of money while getting the same benefit?
The placebo effect haha
I wish I could believe in something and it actually happened... Fortunately I'm quite fanatic and ruthless about my sound, so the chances of a placebo are less... thankfully!
Though I take your point!
mikefarrow said:
hello hone -u2, you could try some double sided sticky tape under your components feet to stop them sliding about.
as for isolation, you could try blutack - cheaper than that ravioli product !
You know I would love to do that! Except I just hate sticky tape for the surfaces it ruins... i really love my walnut finished veneer on my rack... Are you able to suggest a way around those sticky marks?
davedotco said:
Does your Mac Mini store music files too....?
If so, then it is imperitive you swap the hard disc for a solid state drive, night and day difference....!
Works on Spotify too, download the tracks to the SSD using Offline Mode, then listen from there. much better than listening online in real time.
NO. I made sure of that before I bought it... I get music from my NAS onto it... I have not had the best experience with Apple drives playing music stored locally, although it is a 256 SSD, I felt when i heard it through the NAS (i.e. streaming one song/album/artist at a time through Audirvana) gave better results... That way the only load the SSD and the memory have are of the OS, and not the data (if that makes sense). So the NAS is connected to my Mac mini by way of an ethernet cable (same way we connect to a streamer) and the mac mini accesses the NAS drive through the Audirvana playlist maker, and it is then that it adds the songs on to the drive. The thing is, I was one of the people before who in my transition period needed to fully believe that coputers could be used as sources... So I did a lot of listening before I finalised my set up... So this is what it is now... NAS>ethernet to Mac mini>USB to Chord.
I have an SSD MacBook Pro Retina as well... But that sounds worse... I feel there are just too many variables in a laptop as compared to a desktop... And Apple's thing of placing the fans so that it goes beyond the audible listening range doesn't really work for me at all! It really is one of the noisiest things i feel, and it goes wild when you run Audirvana...
Spotify is great for finding music, but I feel the stream isn't clean enough... and there are these occassional times when it sounds lean or too fat... basically I feel there are inconsistencies...
I play Highres masters or my other CD rips...
Thanks for your suggestion though
[/quote]
It is only worth isolating equipment if it is microphonic - it picks up vibration and replays it through the speakers. Many electronic components change parameters when stressed physically. Valves are the most sensitive, but capacitors and resistors can also be sensitive. HOWEVER, in these days of surface mount components, the components are so small and firmly held that in most cases the problem doesn't exist.
How to tell - turn your amp way up with no music playing. Get a pencil and tap the case of the device you suspect is microphonic. If you hear something out of the speakers, then it may be worth looking at isolation. If the speaker remains silent, pour yourself a glass of wine and worry about something else.
[/quote]
Hi
Thanks for that...
Have tried that experiment tons of times before, my ATC preamp proved to be pretty immune thankfully, didn't do it on the amp as my speakers are Active... I thought there might have have been something at the top of the preamp initially, but no there wasn't much to it.
I wonder though (just thinking aloud), wouldn't the nature of vibration caused by internal components have a slightly different (maybe a more regulated) pattern of oscillations, than a pencil from the outside? So maybe the pencil test is good but not enough to mimic the actual problem? Just wondering...
ellisdj said:
If you are using the Mac to play ripped music there are quite a few things to consider - and I think you are right to consider isolation - especially when ripping CDs. I would do all my ripping and playback powered off the battery and not plugged in. Attaching a noisey switching power supply to any systems anywhere in the system adds noise and woresens the sound. PC environments are extrmely noisey and you have to reduce it as much as possible. Its also supposed to make the ripped music sound worse as well - I have not tried a linear psu on a disc drive when ripping yet to compare.
Hi
Thanks for your reply...
I have a mac mini... It doesn't have a battery... I use my macBook pro with retina to put my music onto my NAS... is that what you're suggesting?
MUSICRAFT said:
Hi hone_u2
Blu Tack.
All the best
Rick @ Musicraft
Hi Rick
Thanks for that...
That was the 1st thing I tried! ... though weirdly enough, in humid climate the blu tak started separating and the oily blue stuff got stuck to my veneers... had to change the whole shelf! I used the Bostik ones... Would you think there are other better ones?
Thanks a lot rick!
Thanks a lot for the replies people! I'm gonna try all these things...
