Any bargain Amps out there if you dont need fancy
At the moment 300 for the Nad is over budget.
I'm not overly interested in second hand electronics in general, repair places where I am are few and far between
muljao said:
tino said:
muljao said:
I'm also interested in the monitor audio a100, because it's small and supposedly sounds great.
Good choice. You can get one for £149 or less. Fantastic value for a fine sounding amp with analogue input, digital optical input and wireless DLNA streaming. It's very compact and has a funky remote to boot.
The only thing is that this is apparently an iPod/pad based amp. I don't own a single ios based item. Although considering the monitor audio came out at 400 pounds and it's amp section is supposed great, I should probably overlook this and simply use the single audio analog input
It's true that it supports Apple Airplay, but you can use it as a conventional amplifier with both analogue and digital inputs so you don't need a DAC. It doesn't have Bluetooth but a simple adaptor can sort that out.
The Denon PMA720AE is so good I've bought it 3 times. I loved it each time but the first two times I got bitten by the 'I could get even better if I just...' bug. Not this time.
Pioneer A30, Onkyo A9010UK and Marantz PM6005 also great amps.
Thanks all for the helpful info.
I went completely sideways on this one. I have a Marantz pm4200 which i really liked but it used to cut out regularly on me. It has been shelved in the attic for the last number of years ready for recycling. I started reading up about this about a week ago and it turns out speakers outside its recommended impedance can easliy trigger the cut out circuit. I was using JPW ML510 that were 6 ohms. The manual says use speakers between 8-16 ohms. I instead bought a set of Cambridege Audio sx-50, 8 ohm bookshelf speakers. So far so good.
For anyone interested Chrisr1718 may have a great deal on an amp if needed, I didn't require one after all.
