drummerman said:Vladimir said:I strongly believe in the "Love at first listen" principle and don't believe in burning in longer than 30min for transducers and few seconds for electronics. GB, your reaction was not good at first listen, however you may have not had the optimal settings with the inputs and that isn't a minor thing like swapping DAC chips and wires would be. So if you like them after all is set, you like em bb. It's meant to be. But don't get used to their flaws, they will bother you even if you think they wont. IMO "Burning in" is a salesman's trick and nothing more.
You're not wrong there.
Initial impressions are usually correct.
In this case the question may be how much more does something better cost. As we all know to well, this hobby can be a bottomless pit.
It doesn't really matter if the OP can't up with the foibles though.
It's not a tragedy regardless of outcome at this price point. The Mojo DAC costs more than the actual speakers (including the amplification), so... 🙂
