Vladimir said:I can tell he bought the wrong speakers for himself, and no burn in, cables, DACs or any other audiophile placebo will make any difference in the long run.
Or we can all take a ride.
Thats a bit brutal, hence the need for a code.
davedotco said:Vladimir said:And that's why Chord made the Mojo. To give people a taste of the venerable Hugo at a lower and affordable price. It probably sounds twice as good as the Meridian.
I think we urgently need a 'code', to help inexperienced readers understand when we are entering a 'Thompson experience'.
	davedotco said:Thats a bit brutal, hence the need for a code.
Vladimir said:davedotco said:Thats a bit brutal, hence the need for a code.
OK, no more jokes.
drummerman said:Vladimir said:davedotco said:Thats a bit brutal, hence the need for a code.
OK, no more jokes.
Yup. Enough sarcasm me thinks
drummerman said:Have you tried blocking or part-blocking the ports?
Second recommendation would be to get some sorbothane feet or foam to sit the speakers on and a good quality, round stainless steel doorstop with rubber inserts for on top. It will help with preventing the cabinet singing in unison with the drivers.
Vladimir said:Ideally you want 2Vrms or more for a consumer unit. 1.2Vrms (4dBu) is used more for pro speakers. I'm using 4dBu on my balanced actives and audio interface.
Typically louder will give the impression of sounding better.
Vladimir said:Line in 1 input sensitivity: 2.0Vrms
Line in 1 input overload: 2.2Vrms
Line in 2 input sensitivity: 1.0Vrms
Line in 2 input overload: 1.2Vrms
Clicky
EDIT: So, use Line 1 (since the Explorer is also 2Vrms output). But be carefull not to use full volume on the Mojo.
Vladimir said:If you don't have loud music blasting at full volume when you switch the Mojo on it should be fine. No sound playing = no voltage passing through.
	Green Bow said:That's the Mojo in a nutshell.
(Also yes my distortion on the lower voltage line in was only very occasionally.)
For me I wonder if I can live with the Mojo foibles. I will need to be very careful. I may plug headphones in and forget last time it was supplying active speakers. To be brutally honest I don't know if I can manage that. There is a workaround somewhat. I could use the Mojo to feed the lower 1-1.2V line in on my speakers. Therefor it will always be running in a lower voltage mode, and closer to my headphones. Grado are 32 ohm so they will need a trickle to keep them happy.
As for the BT3 I think they may still be softening and burning-in. Or it's brain burn in as davedotco mentioned. Today they really laid back with a couple of CD Flac rips. The first few tracks of Enigma - Cross of Changes was brilliant. (I was like, "Ooof look at that". Woah seriously I wasn't expecting that, etc") Then a track later sounded a bit more average. The Meridian Explorer was always like that though a little. It gets confused sometimes or the recordings do. (I know What Hi-Fi mentioned the DragonFly v1.2 did timing better.)
I am betting a new interconnect for the BT3 will be great. However I do still vaguely wonder if you folks were potentially right. Maybe I should have thought for longer before buying. I was reading back, and googled again the AVI ADM 5 that drummerman mentioned. I sort of ruled out more expense though. I think at £350 the BT3 were a bit rich. I got them cheaper and for £220 (Peter Tyson) they are good for budget. On reflection I might suggest the MR1 for £300. However I have no real compaints. Plus I need to consider them once I get a new interconnect.
Vladimir said:I strongly believe in the "Love at first listen" principle and don't believe in burning in longer than 30min for transducers and few seconds for electronics. GB, your reaction was not good at first listen, however you may have not had the optimal settings with the inputs and that isn't a minor thing like swapping DAC chips and wires would be. So if you like them after all is set, you like em bb. It's meant to be. But don't get used to their flaws, they will bother you even if you think they wont. IMO "Burning in" is a salesman's trick and nothing more.
