Hi Frens,
Living Hall size in feet.
Length = 20’
Width = 13’
Height = 9’
Equipment:
Optoma HD65
Screen 110” or 120” Diagonal
Yamaha AVR RX V-450
Denon [style="color: blue ! important; font-family: verdana,geneva,lucida,'lucida grande',arial,helvetica,sans-serif; font-weight: 400; font-size: 13.3333px; position: static;"]DVD[/style] 1940
I’m planning a new 5.1 setup for the above mentioned living hall.
The Setup will be used 100 % for Movies.
I ve narrowed down a few combinations..
1. Wharfedale 9.1 + 9 CS/CM + 9 DFS/9.0 + SW 150
2. Wharfedale 10.1 + 10 CS/CM + 10 DFS/10.0 + SW 150
3. PSB Alpha B1 + Alpha C1 + Alpha LR1 + Subseries 5i
I’m yet to hear any of the combinations above. I have a few queries which you guys could help me with…
1. Since the 10.1 is rear ported will it make the screen move/wave when in operation ? As the speakers will be slightly in front of the screen and towed in.
In that case is it wiser to go with the 9.1 combination ?
2. The 9.1 is quite old which makes me wonder if it is the right choice at this point in time…?!?
3. Should I get the 9/10 DFS or the 9.0/10.0 for Surround Sound Duty ?
4. Will these speakers be able to fill the Room Size mentioned or do I need larger Speakers ?
5. Any current owners of the above mentioned combinations could give some feedback….
6. Any other packages I should consider ?
Thanks. ;-)
Length = 20’
Width = 13’
Height = 9’
Equipment:
Optoma HD65
Yamaha AVR RX V-450
Thanks. ;-)
