Hello
I got a few question's about assembling a 3.1 audio system for my small appartment
The living room it's self is around 20 square metres, however the theater room is about 10 square metres, so 5X4.
for the 3.1 system i have kinda a budget, wich is around 3500 Euro.
I need a receiver, tough, will be either a Denon/Marantz or PIoneer,but not sure how to spend the rest of the budget, will i go for 2 small fronttowers, with a center, and will i buy the subwoofer later.
Or would i go with some bookshelfspeakers on a stand, add the subwoofer their, and buy the center later on.
I will post later on a photo of the room, tough, the speakers will sit pretty close to the wall.
In terms of speakers i have on my list to listen are:
-Kef Q900, but i think those will look to big in my room?
-B&w Cm8 SII, only thing i would think they could be bad in the room because of the rear ports, the speakers can be moved a lil bit from the wall, but well, maybe max 2 foot away.
Other speakers i also would love to hear are the Kef R300 and maybe the b&w cm5.
What i hope to accomplish wiht the setup?
It will be used for about 80 percent watching movie's and listening to 20 percent for music.
Music i listen is Rap, hiphop, the 80's,90's and some classic music .
I hope to get an audition some where during the big holliday in july, than i got some more spair time .
Thank you all for the future advice
Kind Regards
Boogie
p.S: before i forgot, around my area, i can listen to b&w, monitor audio,Dali, kef and i spotted also a Klipsch dealer nearby.
Kind Regards
Boogie
