After reading this forum, I just could not help, but register and participate in the disscussion. Firstly Yamaha should not make such comments about a unit being expensive (so there won't be any problems) If they are cheap ! (then you will expect problems) Lame escuse for a respectable company. Secondly the RXV 3900 and the RX Z 7 are not that cheap either, They cost between S$3000-S$3500 between them. Transformerbc was spot on !! because I purchased the same model the RXV 3900, and had the same problem. It's not a soft pop sound mind you " It's loud when the volume is cranked up. Do these engineers want something big to happen ? and then get on to it ?? Too late isn't it. What logic is this ? cheaper sets will give minor problems, and expesive ones ( no problem ) because they are flagship models ? Dealers in the far east had encountered this problem, and Yamaha Japan has acknowledged it when a report was sent to them, and they are working on it at this moment to solve the matter. Thirdly I have been a subscriber to WHAT HI - FI magazine since the mid nineties, mainly because of the publishing editor whose comments were without prejudice and diplomatic ( Rahiel nasir and Andy Clough ) respectively. They never slammed down a consumer accusing him or her of being speculative. They always gave the consumer the benifit of the doubt, until thourough investigations were carried out by the respective manufacturers. [EDITED BY MODS - PLEASE DO NOT ATTACK OTHER FORUM MEMBERS]
Finally the DSP Z11 is of a higher quality in sound as far as the Audio is concerned, which to some may be a little tamer than the aggressive RXV 3900. Bigger transformer, better chips, more speaker terminals, bigger capacitors etc. But the DSP modes should work on the same principal isn't it ??????? After all it is Yamaha's patent.....no 5,261,005.
