Which speaker package for old Onkyo??
sta99y
137
Hi my friend has just picked up an Onkyo tx-sr605 on the bay, he has asked which speaker package to use with it as I think Onkyo is rated at 6ohms, he likes the Kef eggs but they are 8ohms, would this make a difference?? Or which other brand partners Onkyo well. Purely film usage, no music listening intended.
Thanks in advance
I used the Jamo speakers (in my signature) with my old Onkyo SR605 (was whathifi's recommended set-up, if I remember correctly) so suggest that could be a good pairing as it worked nicely for me. Alternatively, Boston Acoustics Soundwaves?
Thanks for ur reply, would Kef eggs out of interest run ok on this Onkyo? If they are 8ohms and the Onkyo is rated at 6ohms will the amp be getting an easier life running them so to speak?! Only great 2nd hand deals can be had.
