- Aug 6, 2016
- 1
- 0
- 0
Juist joined, and am looking for advice for replacement system.
Started (many years ago - early 1980s!) with a Rotel amp, linked to Technics SL20 tuntable, Kef Corelli speakers and a tuner (can't remember). The amp and tuner eventually died, and replaced system with a Cambridge Audio Sonata mini system,still linked to the Kef speakers.
Now the DAB on the Sonata has died - FM and CD still work,. DAB started sounding like it was "nearly" tuned for about half an hour before it finally sounded ok, but now can't pick up any DAB signal. I got the local aerial man to check signal and he says dipole aerial is perfectly aligned - have to use external aerial where we live.
Looking for replacement system - needs to be small, and would like to be able to use turntable again, and keep using the Kef speakers which are still good, so am considering the Onkyo PHA1045, which seems to tick all the boxes.
What do people think about this as a choice, or is there another system that could be considered?
As you can guess I am not an audiophile - just want better quality than you get from boxes from the likes of PCWorld.
