Yep. Go and have a look is your best bet. You'll need to avoid the big chains and go somewhere that will have calibrated each set. That way you can do a fair comparison. I'd expect any of the current / new 1080p Panny plasmas to give the Sony a run for its money. One word of warning though. Grayscale is way off the D65 standard out of the box on pretty much all recent Panny plasmas (not sure about the Sony). This isn't unusual. Grayscale on most TVs is off out of the box. The problem with Pannys is that the controls you need to fix the problem are hidden in the service menu. If you want to get the best from your investment, budget about £250 for an ISF calibration. I'd recommend this for any TV though.
Properly calibrated, the higher end Pannys will beat anything else out there right now on picture quality, with the exception of the much more expensive Pioneers.ÿ
