- Aug 10, 2019
- 2,556
- 5
- 0
My 10+ years old Pioneer CD player gave up on me so I bought the Marantz CD5001 as a replacement. I want to get a new receiver to go with it, so I am looking at the available Marantz receivers to stay with the same brand - it is not a requirement though if anyone has a better suggestion. Since I am on a budget I figured I would at least look at the possibility of buying second hand. I want to upgrade my old speakers as well, but that will have to wait until I have saved up enough money to get something decent.
From what I can tell the current model from the Marantz homepage is sr4021, the previous is pm7001 and the one before that was pm7200. Is there any significant difference between these 3 models, or would anyone do?
I listen to rock/rap so my current thinking is to get floorstanding speakers (RS6?).
