Which floorstanders?
I need some advice. I am thinking of upgrading form my Ruarks to floorstanders. I don't have a massive budget though. Also they must be flexible on positioning. The most I could go up to is £700. Does does anyone have any suggestions.
gregory
45
i would have thought the ruarks are musical and detailed but if you must have floorstanders the rega r3 are wonderful,come in a range of real wood finishes and are easy to place.
Andy Clough
776
Also worth listening to the Monitor Audio Silver RS6 (£600), Acoustic Energy Aelite Three (£750) and Triangle Altea ESW (£795). We gave them all 5 stars.
I have to 2nd Gregory here, the R3's are fantastic and are not too fussy about position due to the side firing bass driver. At £498 they are well within budget. Should give you some left over for some speaker cable (Unless you want to keep your current cable).
