Thank you. To clarify, are you suggesting upgrading the cartridge instead to an Ortofon 2M Red?
( 2MR ) reduced height range for rega
Ortofon 2MR features a specially designed cartridge housing tailored for Rega turntables and tonearms matching their requirement for low-form factor cartridges. With its narrow 14mm Deep cartridge housing, it seamlessly integrates without a need for modifications or spacers under the tonearm, enabling quick and easy mounting with just two screws
VTA - WHY DOES IT MATTER?
The Vertical Tracking Angle (VTA) is the angle between the pivot-point of a cartridge's cantilever and where the diamond touches the record groove. Ortofon cartridges are constructed so that the cantilever angle corresponds to the 20º record cutting angle, when the cartridge is loaded with recommended tracking force and the cartridge base is parallel with the tonearm, which in turn is parallel to the record surface. As a result of this design, if your cartridge is ever mounted on a tonearm where it must lean even slightly backward compared to the record surface, the VTA will not be correct and you will lose important musical details.
14mm The existing 2M range is well suited to many tonearms in the modern market, and is perfectly at home on tonearms with adjustable VTA. However, there are many tonearms uch as Regas, where the VTA is not adjustable and the regular 2M cartridge height is too high. Similarly, there are instances where you may wish to modify your turntable with a thicker mat or platter upgrade and you need to compensate with reduced cartridge height.
