Just found the answer to my own question!gel said:As above, just bought a new amp and what to know how to use it? Thanks.
Yamaha 3050 amp - just reading about DTS X on the WHF page and it says to use it in a 5.1 setup, so I am cool there. What's the 5.1.2 setup for Atmos? 5 speakers 1 sub and two other speakers?rocketrazor said:What Amp did you buy? Atmos you need ceiling or up firing speakers. It can't be done withint a 5.1 set up, it needs to become 5.1.2 or 5.1.4 etc etc. Also didn't really thing DTS x was much benefit if you only have 5.1 setup? Might be wrong here though
How high? Tamacdiddy said:you will need to add two more ceiling/height spks for Atmos/DTS-X.
*music2*
gel said:How high? Tamacdiddy said:you will need to add two more ceiling/height spks for Atmos/DTS-X.
*music2*
My ceiling is massive and triangular, these other two speakers would need to go on the side walls.rocketrazor said:it will work, I'm just not sure on the benefit, I think you need more speakers to really benefit, again not sure but that's my understanding.
for the .2 in 5.1.2 it is indeed Left, Right, Centre, Left rear, Right rear, one Sub and two ceiling speakers or 2 upfiring speakers. Though I believe you have to coat your ceiling in a specific type of paint to get the bounce of the ceiling.
Hi mate, ta, my ceiling is triangular though and really high, I think these speakers would need to go on the side walls.simonlewis said:Hi gel i use CA MINX MIN12 they come with a bracket that you can screw to the ceiling.
Ah cheers, that is interesting.Benedict_Arnold said:X = number of speakers around the room.
X=1 means mono. X=2 means stereo. X=3 means stereo plus a centre. X=5 means two fronts, two surrounds (not necessarily backs) and one centre. X=6 means you add one back. X=7 means you add two backs. X greater than 7 isn't available (much) for home use, except, possibly, in Japan. The additonal speakers would go down the sides, and most of us don't have living rooms / movie rooms the size of your local cinema, so probably pointless.
Y = number of subwoofers.
Can be 0, 1 or 2, but you can always wire up two or more subs to the same output channel.
Z = number of upward firing, overhead or height speakers.
Overheads are best.
Atmos speakers that bounce sounds off the ceiling don't work well, if at all.
Height speakers are the compromise.
You need a minimum of two overheads for Atmos.
DTS:X and Aura3D (or whatever it's called) need only one overhead - sometimes referred to as the "voice of God".
Personally, I think one of the reasons DTS:X is more popular in cinemas, and may come to rule at home (much like the technically inferior but longer playing VHS beat out Betamax) is beause it uses fewer overhead speakers. Much easier to fit speakers down the walls than in the ceilings, especially if your local cinema stems from the art deco period (or earlier) and probably has some sort of protected status on its ceiling. Likewise you'll do less damage to the artex at home fitting one speaker in the middle of the ceiling (possibly replacing that light you bought at Ikea and have regretted doing so ever since), than fitting 2, or as in my case, 2, then another 4 later.
gel said:What about these two speakers for going on the wall?
https://www.hifix.co.uk/speakers/home-cinema-speakers/rear-surround-speakers/b-w-ds3-dipole-speakers-pair
Don't they work? Damn.nugget2014 said:gel said:What about these two speakers for going on the wall?
no................
Cheers mate. Looks good.simonlewis said:Hi gel have you seen my dolby atmos speakers.
https://www.flickr.com/photos/69466459@N04/21064489193/in/dateposted-public/
Cheers - that's great! Problem I have a bit is that they have discontinued my speakers now. I can still get the new sub but not speakers, I will have a look around. TaBenedict_Arnold said:Surrounds should go at ear height, so they say, which is about 3'6" or so above the floor (assuming you're not an eight-foot tall professional basketball player sitting on a bar stool). Mine are actually set at about 5' off the floor and they seem to work fine, although, I suppose, sounds seem to come form "up and over there" rather than "down and over there" - which probably means next year's big thing will be in-floor or in-skirting-board speakers as well, shudder. You notice it more with the sides than the rears.
Unless you're going for in-the-wall and / or in-the ceiling speakers, I'd suggest starting off with second hand bookshelf speakers off fleabay that you can hang off screws in the walls or put on cheap stands (or bookshelves even, if you must) and go from there. If they work well enough, keep them. If not, flog them on for more or less what you paid for them. Spend the money on a big powerful 12 or 15 inch subwoofer going down to below 30 Hz instead. Surround sound is all about effect, not audiophile stereo sound, remember.
Some people (salesmen mostly) say you need the same brand speakers all around. I'd say that's fair for the fronts and centre, but not for the surrounds. Just make sure they're about 50 WPC capable, around the same sensitivity as the fronts, and that the woofers are at least 3 inches in diameter. Otherwise they won't move enough air.
If you're going for height speakers rather than in-ceiling speakers, I know I keep banging on about them but look at the Klipsch RP-140SA speakers, or figure out what you could do with a pair of cheap secondhand bookshelf speakers and a chainsaw for much the same concept.
Add-on speakers or "Atmos speakers" that bounce sound off the ceilings are generally regarded in much the same light as chocolate teapots.
