WHF Q: ProAc Response D18 + Naim UnitiLite
Andrew Everard
1,878
Well, I can't speak for Mr Clough, but IMHO the UnitiLite would have sufficient power to drive the Proacs unless you were in a huge room and like your music at very high levels.
However, it's not a combination I've heard together, so I'd suggest a long, hard audition would be in order to find out whether it meets your needs.
NHL
83
I owned a pair of small ProAc's as a student. The magnets had the same diameter as the cones! Serious business, like WHF! Cheers
Singslinger
16
Once, in another hifi lifetime, I briefly plugged a Naim Uniti into a pair of ProAc D 18s. They worked OK together so I'm guessing the Lite will do the job. Whether you'll be happy with the sound though, is another matter. I think the D18s deserve at least the SuperUniti, but best to listen for yourself. Good luck!
Ketan Bharadia
44
I think the UnitiLite has the power to drive the Proacs, but doesn't have the resolution, transparency or finesse to get anywhere near the best out of them. The SuperUniti, on the other hand, is a different story.
