The Dyns have a 87db efficiency so are not the easiest to drive.
On paper your K2 looks as if it will be ok, but I doubt it will get the best out of the Dyns.
If your heart is set on the Dyns - go for it, but maybe get a demo with a higher specced amplifier and try to compare.
I did not say that, what I actually said you quoted.So because they are 87 db speakers they are not easy to drive ?
Spec can be deceiving i had a pair of revels that were rated 87DB but quite frankly some of the easiest speakers to drive. But then it can be the other way like PMC (2023) where they state a rating like 86 and there more 81-83db, an absolute pig to drive.
But as you say dyns are famously hard to drive even with high wattage amps
I talked to Audio T about the Evoke 50 and they recommended to get the bass controlled, an amplifier in the region of 8 to 10K.
Would the size of the room be a factor then? Ie a bigger room would need the same speaker to play louder for the same effect as that in a smaller room? Therefore you would need a more powerful amplifier in a larger room?sensitivity has nothing to do with speakers being hard to drive
Some small speakers it might limit the max spl dispite other small speakers can handle 100 watt with higher sensitivity
Big speakers with 87 db just means you need more power for loud music than speakers with 90 db sensitivity
Impedans and electrical phase angle (i think it's called) tells you more if the speakers are hard to drive (makes the amp hot trying to play loud) since most speakers play loud enough for most people with 100 of clean watt
Im driving my 85db rated (could be lower) speakers with an amp that has about 33-35 watt in 8 ohm and 54-56 watt in 4 ohm, they are not hard to drive, just needs more power to play loud compared to 90db sensitive speakers
I think this is a given.Would the size of the room be a factor then? Ie a bigger room would need the same speaker to play louder for the same effect as that in a smaller room? Therefore you would need a more powerful amplifier in a larger room?
Where in the world are you. You seem hung up on mains conditioning, do you need it?Just to make this clear, I changed my mind about the Evoke 50's, I know there the number one option for elevating sound quality, but it's just too much money.
To make my first post make more sense. Would the ultra expensive Dynaudio Evoke 50 mean buying a new amplifier. The answer is a probable, yes.
So let's say I have a budget of 1K or a little more, I think a used K3 amplifier would be nice for the Emit 30's. There plenty of power and would look nice with my K3 DAC on my rack. Or I could get some sound proofing, but it all looks ugly. I think aesthetics are important to me.
Or a mains conditioner, like the Audio Quest Niagara 1200 at £900. The reviews suggest that it deals with low level detail, the grunge so to speak. I could get a 60 day return on it. Who knows. It's all fun at the end of the day.
The other thing is that Leema Acoustics Tucana 2 is something I really wanted. I just don't want to spend that much.
Have a good night.
I really think in your case it's not the number one option, but the amplification. I also don't understand why you think budgeting for a K3 (which would be almost no upgrade at all) + a f**k-ton of money for a mains conditioner is preferable to throwing all that budget towards a proper amplifier. I mean if this is the "upgrade" you're considering, I'm just gonna move to the "do nothing" camp. But it's your money, of course, I'm just puzzled.Just to make this clear, I changed my mind about the Evoke 50's, I know there the number one option for elevating sound quality, but it's just too much money.
Okay, you want to spend as little as possible, and get the biggest bang for your buck.Just to make this clear, I changed my mind about the Evoke 50's, I know there the number one option for elevating sound quality, but it's just too much money.
Have a good night.
Such as? Suggest a brand that will better his Dynaudio Emit M30, given the OP has reduced his budget from £2700 to £1000.Dom. Get whatever speakers you want regardless of cost, connect to your existing amp, have a listen. Don’t buy mains conditioner.
So what have you decided after all of that?Thank you for your input's, TrevC, Plastic Penguin, MUSICRAFT and everyone else.👍
Dom fwiw, we don’t use any mains conditioners or after market mains extension blocks.
