what to spend my money on?
I want to buy a true hd tv preferably 46 inch or larger and blue ray dvd, amp and speakers or theatre system. My budget is 2000 pounds max and would like as high a spec as my budget allows. Can anyone offer any help on this as i am by no means an expert?
Panasonic TH46PZ85b £1099.95
PanasonicBD35 £189.95
Sony STRDG820 £229.95
KEF 1005.2 £379.95
Leaves you £100 for cables
Not a bad start. See if you can get discounts for buying all in one go, maybe get free cables.
The above prices were just dragged straight from the Richer Sound website, so include no warrenties etc.
You have not mentioned the size of your room or your viewing position. What other sources will you be connecting?
Hope this helps
