What DVD discs?
richardw42
299
Assuming the player is not able to play discs from all areas. You should be looking for region 2 for DVD, region B for blu Ray diSCS
Youll also be able to play those marked. As region 0 and ALL REGION.
abacus
Most Blu-Ray players can be converted to Multi-region DVD if required, and you will find many remotes available on EBay that will do the job. (Make sure your model is included in any remote you buy) Many dealers already have the remotes and will do it for you for a minimal charge.
Multi-region Blu-Ray normally requires a hardware modification and so tends to be expensive. (Many Blu-rays are already none region specific, but always check first if purchasing from outside Europe)
Hope this helps
Bill
