- Aug 10, 2019
- 2,556
- 5
- 0
Hi Everyone!
I would like to buy a new budget system and move no further for a while (say in the next ten years 🙂 ).
I have read excellent reviews (posts etc.) on the new Dali Zensor 1.
Do you think they would match the cambridge audio 350a amp? Or are they better with nad 316bee? (I am considering these)
I also have the possibility to buy the harman/kardon mas-100 speakers (only the speakers!) for a very low price. Do you think they are better then these dalis? (I think the dalis may go deeper and they are louder as well...) Would they suit the above mentioned amps?
What about the following combinations?
CA 350a + mordaunt short aviano 1xr?
NAD 316bee + mordaunt short aviano 1xr?
Does it worth it to buy the NAD 326bee, cos it has 2 sub outputs? Would it make it possible to use smaller speakers in a larger room (like 5*5 meters).
Actually I do not get the idea, why small speakers are not suited for larger rooms, when they are so loud even at moderate volumens.
Thanks for all your help! 🙂
Levente from Hungary
