weak wifi signal due to router far away - help needed please!
If your ISP is BT, get one of these:
images
don't know why this didn't work
Our sky router is in the kitchen connected to the ps3 and we use a laptop and ipad in the lounge which is approx 30 feet away but we have a very weak connection, particularly on the ipad.
When we take the laptop or ipad nearer the router they work fine.
What can i get to boost the signal in the lounge?
I had a look on ebay and found these:
http://www.ebay.co.uk/itm/150Mbps-WIRELESS-N-USB-ADAPTER-LAN-NETWORK-WiF...
but maybe barking up the wrong tree??
the laptop has wifi built in.
i'm about as un blue peter as they come!
isn't there anything to plug into the laptop i can use?
i've already got homeplugs connected to the lounge tv for sky anytime +
How old is your router? If its a wireless g router then that is possibly one reason as to why your signal is weak. Another is if you have thick walls.
You could try increasing the height of the router.................... :grin: it does work though!
A Wireless N router is much much better and its indoor & outdoor range is supposed to be x2 that of wireless g.
Your iPad runs off wireless N and so having it hook up to a wireless N router would make for a much better connection. If changing to a N doesn't solve the problem then you may need a wireless access point. Such as: http://www.buffalo-technology.com/en/airstation-nfiniti-highpower-giga-wireless-n-router-access-point.html
think its about 3-4 years old so not sure what type it is.
maybe i'll call sky and see if they do a better router first.
appreciate all the ideas
so homeplugs should sort out the issue with the laptop, but how do i boost the ipad wifi signal??
If you have a spare wierless router kicking about (or buy one s/h from ebay, you can pick 'em up for peanuts) use it as an Access Point...
sorry to be a bit thick, but how does it work? how do you connect it up etc??
i have called sky and they are sending out a new n router so will see if it is any better.
thanks guys
quick update:
new router from sky received and it's miles better. even the ipad works well now on the wifi. thanks for the advice
