Wall mount for Sony KDL-W2000 or KDL-W3000
Hello. I am buying a new LCD set (Sony KDL-W2000 or KDL-W3000) and i need a good wall mount to put it. Could someone recommend me a good one that can tilt 15º or more? Yes i could buy it from Sony but they are sooo expensive... Thank you and keep up the good work.
Go the Dixons website and get your slef either the tilt or fixed versions of OMNIMOUNT's universal wall bracket which is what I have bought to mount my new 42 inc Plasma. In Currys they're £169.99.....On Dixons online the same brackets are around £70
Thank you for the response. I am in Portugal but i will see those shops too... i want to see the good brands to help me choose the right one... i will check OMNIMOUNT's universal wall bracket.
viva llun,
Eu tamb‚m tenho um sony KDL-W2000 comprado na loja San Luis, e comprei na altura por ?49.90 um suporte universal comercializado por eles para fixar na parede plasmas/lcdïs at 42ïï, at‚ … data impec sem qq tipo de problema.
m.cumprimentos
tiago b.
