Very interesting demo today...
drummerman
540
the_lhc:
al7478:But I'm being slightly mischevious. If I had a bigger place* I'd consider a sub and probably try one if i could get past the nuissance of changing the level all the time according to the appropriate listening level on that day, at that time...
Err, surely the sub output on the AVIs is variable, so that once you've got the sub level set up correctly the sub volume will just go up and down with the speaker volume?
yes
Alec
478
drummerman:the_lhc:
yes
Right you are chaps. Sorry. I'm a subwoofer ignoramous who should not make assumptions.
Alec
478
drummerman:the_lhc:
yes
Does this apply to any sub one might use with them?
The_Lhc
1,176
al7478:drummerman:the_lhc:al7478:But I'm being slightly mischevious. If I had a bigger place* I'd consider a sub and probably try one if i could get past the nuissance of changing the level all the time according to the appropriate listening level on that day, at that time...
yes
Not sure it's possible to answer that question definitively, there are an awful lot of subs out there, but it's not dependant on the sub, it depends on the sub output of whatever the sub is plugged into, provided that output is variable (ie goes up and down with the volume control) then this will apply.
It'd be a major PITA if you had to change the sub volume every time you turned the amp up or down. It'd be unusable in fact.
JohnDuncan:Simon Lucas:
JohnDuncan:The bass on the AVIs was not so much subdued as totally absent, and the PMCs were not much better
Bass-wise. They were better speakers (obviously).
From memory, in pure SQ terms, how do the PMC actives compare to standard DB1S? When I tested them with my Arc the bass response was impressive for the cabinet size.
