Naim Nait 50 Anniversary
....that bright power light, even on standby
Sounds like it goes between bright and very bright - meaning theres little noticeable difference.
All the more strange since as it's about the only thing they needed to get right on that simple front panel 🤔
The sound is the most important thing of course, but still, I'd have to sort that out.
Could be quite an easy job for someone to fit a higher value series resistor inline with the LED - to make it (much) less visible on standby.
That way it should be much easier to recognise it displaying 'on'.
White LEDs, like the new car headlights, great in theory 😎
I had an hour late last night and first impressions were … detail and sound stage, both not usually traits of Naim stuff at the affordable end in my (limited) experience of the brand. It almost made my speakers sound electrostatic.
I’ll have a little bit more time today and over the weekend.
It's a very good little amplifier but I am still not entirely sure about it's sound.
There is no doubt in my mind that 'transparency' is top notch. It is a window into the recording. A very clean, polished window. It is also quite punchy, coherent (it 'flows' nicely and sounds together) and very, very detailed.
There is, however, a very slight mid range leanness (!) which extends into the treble and bass can also be on the very slightly soft side. This one is a weird one though as some bass heavy tracks sound powerful and on strict time, others are perhaps very slightly loose. Perhaps it's just very accurate? I don't want to over state this as this may be unnoticeable to anyone not having had fuller sounding amplifier. The upshot of this is speed, it's certainly not a slow amplifier nor is it fatiguing in the slightest!
This all could of course be an amalgamation of my system but its all I have. I do however have other amplifiers to compare with.
Saying all this, it certainly is a fun product to listen to and can sound exceptional. You'd never guess this comes from 25watts. It may just be a case of getting used to a 'new' sound.
I must say though, there is no comparison to the Hegel I had. That amplifier felt stilted, mid range forward and two dimensional in comparison, none of which the Nait is.
I will persevere and see how it all comes together over the w/end and I have not tried the phono stage yet. More to come.
Reactions: matthewpianist
Let the amp burn in too… marginal improvements will occur but it will open up a tad…..
That’s ok thanks LR. It is a low hour used one so should be fine. Anyway I am having fun listening to it! I was being super critical as one should be spending £2.6k on it. Luckily I did not. Even at full RRP this is probably an exceptional product but as everything, no matter what the cost, is not beyond some criticism however slight it may be.
What I did not mention was what a gorgeous looking and seemingly well made amplifier it is. Again, so it should be for the money but that is also not always the case.
I also like that it was made just down the road from me. More to come
Reactions: The_Lecht_Rocks
All I can say about the NAIT is I had an original 45 years ago. It was very good at that time but not impressive after my upgrading to a Burmester 838 MC pre. MM basically sucks. Upgrading to a MC cartridge and especially with a pre/power setup is another world. Its not cheap, its called audiophile, and worth every penny
Ok 🙂
I was listening to classical through the Nait (with an MM), volume at 8 o'clock (speakers around 90/91db/w). Very smooth, lovely detail and then, the orchestra kicked in. I nearly jumped out of my seat. Impressive dynamics this little fella has.
Call me music lover, not audiophile 👍
Reactions: Alex1969
Having had more time with this little amplifier I feel now I can give my subjective opinion 'a little more objectively';
Is this a giant killer? Perhaps, likely ... but I am not in a position to really confirm or deny this, my other amplifiers are not in the High End. However, seeing some comments elsewhere where folks use £10k sources and even more expensive speakers, some even abandoning very expensive pre/power combinations lead me to believe there may be something in it, provided you don't need mega power. However, even 25 watts can go very, very loud with sensitive speakers. I can confirm this even with 91db/w ones.
What I am certain about is that the Nait is a/ incredibly transparent, b/ has a cohesiveness that makes music inviting and endlessly enjoyable and c/ is very dynamic which makes every track an event without insulting my ears.
It also benefits from warming up 10 or 20 minutes.
Quite frankly and imho, Naim really created something very special here.
I have heard there is a BlackFriday deal on for £999. A few remaining
But if it had been worth £2700, it would still be £2700. No doubt it's a good amp, but the later asking prices I think better represent its place in the market. Any idea how many were made?
Reactions: Alex1969
It was always a niche product. No remote, no features compared to others. Doesn’t appeal to many and it didn’t to me but I am glad I did not listen to myself.
Reactions: jjbomber
