GSV Ethics Gradient
Moderator
I have no experience here, but that sounds implausible to my cynic's ears.using alternatives may degrade the performance or even damage the amplifier
Naim amps used to blow up regularly if not connected as recommended by them. It’s a long established problem as Naim used never fit (protecting) Zobel networks, meaning they rely on the cable to load the output safely.I have no experience here, but that sounds implausible to my cynic's ears.
I see - seems unwise to me, but what do I know?!Naim amps used to blow up regularly if not connected as recommended by them. It’s a long established problem as Naim used never fit (protecting) Zobel networks, meaning they rely on the cable to load the output safely.
Well, I can’t think of another SS amp that’s equally vulnerable, but they maintained it delivered better sound iirc. On balance though, not blowing up sits higher in most customers requirements!I see - seems unwise to me, but what do I know?!
🙂On balance though, not blowing up sits higher in most customers requirements!
Classic sardonic understatement.
(Something that could only really come from - and be appreciated by - English people).
'On balance' 😆
This most definitely was the case on older series amps - Olive, Chrome Bumper etc, but modern lines are no longer this prohibitive - such as the 5si, XS2 & 3, SupertNaits.Naim amplifiers are designed only to work with Naim loudspeaker cable and using alternatives may degrade the performance or even damage the amplifier.
It’s irrelevant as long as the correct speaker cable is in place. It is that which protects the older type Naim amps. However, the condition I quoted earlier is still in Naim’s manual.What about the internal cable inside the Speaker
I took your advice and got Linn k20 cables, they seem to be fine......And keep away from silver type speaker cables with Naim, I couldn't stand the sound of my Nait xs with some qed silver anniversary, if you need something a bit less expensive than the naca 5, tellurium etc, I'd recommend the linn k20 (aka naca a4), I doubt you'll find it new, so eBay is your friend here. I actually have a couple of 3-4 metre lengths of it kicking around, oh and mogami quad core 2972 is pretty good also.
Did u got the chance of listening to Rega? I’m also in the same boat as you and I don’t know which one to choose between Rega and Naim.I took your advice and got Linn k20 cables, they seem to be fine.
In the meantime I continued to listen to the naim nait xs 3 for a while, it seems to me that it sounds good if it weren't for the bass in some passages it loses a bit of definition.
In the meantime, I am waiting for the new Rega Eliit mk5 to arrive from my supplier to make a direct comparison with my ears.
In the meantime, there is someone else who can give me an opinion on the two amps naim and Rega.
I posted an extract from the current Naim amplifier manual in #24 above. Essentially, some of their designs need the speaker cable load to stabilise the amplifier. Look up zobel networks or look in Naim’s own forum and you might find more. All I’d say is use their suggested cable and you’ll be fine. Or you might agree with me that it’s an unnecessary flaw.Rereading our comments on this forum I focused on the problem of cables.
I have no experience in electronics and little knowledge of electrical engineering, reminiscent of when I was studying, more than 40 years ago.
I would like to have more technical clarifications to understand and justify the problem of cables for Naim amps, degrade performance or ruin the unit ???
Keeping in mind that however on the other side of the cable is the loudspeaker with its speakers with their impedance with their load.
A good amp manufacturer must offer products that sound better than the competition all other things being equal.
Equality of conditions means the same speakers, the same sources and of course the same cables, knowing that the response of the amplifier can vary from speaker to speaker.
It is true that these elements of the music chain can affect the quality of the sound, but this is true for any amplifier.
The comparison must be made on equal terms.
How is it that an amp can explode or get damaged by cables.
If so, for me Naim is disqualified.
...where they also advise that their cables are directional (still, they're hardly alone in that 🙄).I posted an extract from the current Naim amplifier manual in #24 above.
I think this goes only for their old amps. New ones should work with any type of cables.I genuinely didn't know about the Naim and using their own cables. When I've home demoed any of their amps only used my Chord stuff.
Another good reason not to buy a Naim.
one would certainly hope so...... 🙂I think this goes only for their old amps. New ones should work with any type of cables.
Seems absolutely nuts if that's the case. Does that mean you can't use Naim cables with other brands of amps?I think this goes only for their old amps. New ones should work with any type of cables.
No.Does that mean you can't use Naim cables with other brands of amps?
