Naim Nait 50 Anniversary
What speaker cable and plugs are you using with it, @RoA ? I only ask because of the messaging that always appears on the back of Naim amplifiers.
I believe the little Naim is pretty cable agnostic. I use VdH CS122 Hybrid but I have this lovely new ribbon cable I will try too. I used it quickly with my Arcam and it seems very good too.
It was always a niche product. No remote, no features compared to others. Doesn’t appeal to many and it didn’t to me but I am glad I did not listen to myself.
To me, it just doesn't feel like the right approach to the product, replicating the original, warts and all. You can easily pick up the original or Nait II for less than the reduced price, and it's all standard parts, so cals can easily be replaced to give it a refresh. With Naim's modern approach to hi-fi after the take over of Focal, they should've modernised it. It would've been very easy to add a remote control, which I think is unforgivable nowadays unless something is being used as a desktop/PC system. And even if they didn't want to add any digital inputs, they could've modernised the available inputs
But they did change one thing - the sound. Tonally it sounds more like other amps now, whereas the original had quite a lean, detailed sound (which I quite liked at the time), probably more like typical Class D amps. Why change that aspect when everything else is nigh on identical?
I don't think anyone else's retro product has bombed in such a way as the Nait has. It'll be interesting to find out the exact reasons why. Maybe any future anniversary products will be more carefully conceived and priced.
Unless things have changed, Naim amps never paired well with solid core cables, and it was usually best to use their own cable to maintain amplifier stability.
Not to defend Naim (it is the only product I own by this manufacturer) but what you are saying was not the point Naim tried to make. The brief was to make the best possible product using modern manufacturing whilst keeping looks/features as close to the Original as can be. The inclusion of headphone socket was as large a hint to outward modernism as they could manage. I agree about the R/C but again, that was not in the brief for a reason and I overcame my initial misgivings quickly about this particular 'issue'.
As to sound, it does not make sound like my other (modern) amplifiers hence it stays. Would it sound the same I would not keep it, naturally.
Yeah, the point of the NAIT 50 I think is to strip back everything and focus on the amplification circuit and quality of components only at the expense of all surplus added extras.
Steve Sells piece here is interesting:
A fifth and final product highlight for Sells is the limited-edition Nait 50, a recent reimagining of the iconic, 1983-released original Nait 1, which, as Sells rightly recognises, “holds a special place in Naim folklore as one of the most magical amplifiers ever made”.
“Tampering with that reputation was not something to take lightly, and designing the Nait 50 came with responsibilities just as significant as those tied to high-end products,” he says.
Naturally, Naim couldn’t simply release a facsimile clone of the Nait 1 – compliance laws and consumer expectations have, after all, moved on since the ‘80s; Sells and his team had to deviate.
“The design process used modern tools, materials and circuits, and incorporated mandatory music sensing with 0.5W auto-off, quiet standby transitions, and soft-start circuits – all while keeping the system free of software,” says Sells.
They created miniaturised versions of amplifier stages from Naim’s classic range, borrowed the volume control foundations from the NAC 552 preamp (albeit without motorisation), and used modern semiconductors to give the Nait 50 extra power and sonic punch.
But there was also an opportunity to recapture the Nait 1’s spirit in more faithful ways. Sells gives one example: “The Nait 1 had a deliberate low-frequency hump in its RIAA curve, and though technically inaccurate, it gave the sound a pleasant aesthetic; we faithfully recreated that in the Nait 50.”
Another is in the input selection. “The Nait 50’s input switch was custom-made to replicate the original’s distinctive ‘clong’ sound when pressed, though behind the scenes the switch activates high-quality reed relays placed next to the input sockets, improving sound quality and minimising input-to-input crosstalk,” says Sells.
And then, perhaps surprisingly, the Nait 50 further aligns with the Nait 1 by also omitting RCA sockets and a remote control.
“Did we make the right decision by leaving them out? I’m not sure. Once nostalgia wears off, convenience tends to call,” Sells admits.
We guess even engineers with CVs as enviable as Steve Sells' can question their judgment at times
Reactions: nopiano
the lack of remote is a bit oversight imo, it makes the whole thing feel like a gimmick. There’s no way that extra circuitry would alter the sound in any meaningful way.
Reactions: Shrek
LR - have you run the WiiM through the NN as would be interested in how that sounded to you. I looked at the £999 deal and started dreaming a little ...
Yeah I did initially but the ICON is on a different level…..
Still, the N50 did well with the WiiM, but the amp is too good to strangle with the WiiM.. it scales very well to a high quality source.
Some NAIM forum users got £10k front ends into the N50!
Not my scene, but shows how good the N50 is….
Reactions: Juzzie Wuzzie
Too much money, not enough sense over there but yes, it is an exceptional product at its discounted price.
Without doubt the NN50 is a marmite product.
What’s not in question however is its ability to pump out an incredible amount of fun, fast paced and rhythmic music… It’s got a grip of my SCM11s , gives incredible pacing to the presentation and dynamism for days.
I don’t need HDMI , optical, remote control, multiple inputs in my wee study…. Just the best quality amplification I can justify and the NN50 fits that bill perfectly…..
I love mine !
Reactions: Revolutions
Naim forum would be the place to ask this.
Imagine the dreams nightmares of any unlucky bastard that paid £2700, if they've seen the current deal 😱
As someone else has said, probably one of the best Hifi purchases for me ever. Would I be upset had I paid full whack? Yes. Not because I don’t think it is not ‘worth’ it, it probably is but that is something you have to decide for yourself in context but because of Naim’s miscalculation and subsequent discounting which, as we can see here, devalues what is a magnificent product that probably deserves to stand up there with some of the very best, regardless of price. I had a dig at Naim over at said forum and promptly got put in my place. Fair play, I should have known better but as someone over there did suggest, they could have priced this at £1973. Naim could also have made it a more personal experience perhaps with a certificate signed by Naim and an individual test print out. Things you dont normally get. Taking it a step further, a Naim photo page with a picture of every Nait 50 sold in situ, in it’s system. Little things which make ownership a bit more special and which don't cost the business a lot. It should not be difficult to sell the above number of units with better marketing. Naim has 10’000 ‘s of customers over the world gained over decades but they failed to utilise even this large demographic.
Saying all this, it has enabled me to get one at a fraction of the price so what am I complaining about 😎
I have now also used the phono stage and am very happy. Next is the H/P stage and to compare this to my separate DAC/HP unit.
