Van den Hul The Wave overkill with DacMagic?
Peter Larsen
106
I would like to squeeze every last detail out of my DacMagic, and therefore consider buying the Van den Hul The Wave analog interconnect, but is it overkill? At the moment I use a Tara Labs Prism 300a. A cable to approx half the price of the VtH.
I also have the QED perfomance coaxial - considering going for the Qed SR75. Worth it?
No, I don't think it will be overkill (although it would be helpful to know the rest of your system). I use a Chord Chorus 2 to good use.
Try and trial if you can, and enjoy!
Blunny89:No, I don't think it will be overkill (although it would be helpful to know the rest of your system). I use a Chord Chorus 2 to good use.
I don't think so either, in fact I suspect that the DM needs a good interconnect - I use Chorus 2 also (XLR though).
Peter Larsen:
I've just seen your other question. The SR is a decent jump on from the Performance - I've had both and still have the Performance connected to my Sky HD box from my DAC. I sold the SR for a decent sum and got a Clearer Audio Silver Line http://whathifi.com/Review/Clearer-Audio-Silver-line/ for £60 (I think) off Ebay. This is a very good cable.
Peter i am using the Tara Labs Spectrum 3a Audio from my DacMagic and i did have the tried the Chord Chameleon sliver plus.
Not impressed with the Chord also tried the Supra EFF-1 But yes you should take a step up from the Prism 300a.
Peter Larsen:
I don't want to shock you but if you want to squeeze the best out of a DAC i wouldn't recommend the dacmagic but a DAC that can make use of a powercord (not an ac supply).
I was on the same road you are now and regret a bit the money i spent on it.
See following topic on what i tried out.
http://community.whathifi.com/forums/t/263585.aspx
