Look, I get the "can I use amp with higher wattage than speaker" question has been discussed dozens of times with the answer "it doesn't really matter unless you turn up the volume too much" and you're not asking for something ridiculous like running 5W speakers with a 100W amp.
However, I'm in charge of finding an amp that will power small 60W speakers (potentially also 80W standing speakers) for a Sonus 40 "home organ", and most four channel amps boil down to at least 5.1 surround amps (which I don't require for the organ, just four channels) that begin at like 120W PER CHANNEL.
Now, we're not talking about regular bass "kicks" here, much rather we're talking about long and loud pipe sounds, of which a good chunk is deep enough to go down to your very bones and potentially put a huge strain on the speakers (I'm not planning on buying a sub here though, in case anyone wants to suggest that).
Would I still be fine to recommend using a 120W amp like this Denon here
for the use of 60W (80W) speakers for classical organ / church music? I don't really feel comfortable at all using a 120W or even 100W amp here, but all decent 50W amps I'm able to find only support 2 speakers or (in case they support 50W) are some very shady china amps I'd rather want to avoid for quality / electrical safety concerns.
Or they are made by Auna, which I no longer trust after a series of absolut unfortunate purchases.
Budget for the amp is up to 400 € / $, preferably though in the 100-200 € / $ range.
