amrgarnder
- Dec 30, 2013
- 0
- 0
- 0
One concept you need to learn about:
"Expectation bias"
Look it up. It will save money to spend on that baby.
"Expectation bias"
rascal6000 said:...and from the hallowed WHF awards for the Supra USB Cable
"It's the sound that matters, and it's here that Supra has worked magic. It's got impeccable timing and good energy, both of which translate into a tangible sense of fun"[/b]
True or false?
One thing I definitely don't want to add to my music when listening to Mozart's Requiem is a sense of fun!
theexcitableboy said:This is not dissimilar to the HDMI cable debate.
To sum it up, the signal is digital. It is not affected by cable quality in the way that analogue signals used to be. Buying a 'better' cable means better build quality. If you're going to take the cable around with you, and plug and unplug a lot, spend just a few more pounds on something a bit more solid.
If it's to plug-and-forget, just buy whatever Amazon has cheapest. Will probably be a Belkin. Doesn't matter. Doesn't make a difference. The end! :wave:
