upgrade but which one?
tj27
30
hi all
have the Yamaha DSP AX863se amp from 2008/09? award winner, been very happy with it & still looks/performs the day i took it out of the box. Basically im looking to upgrade to a newer amp.
Choice's are:
Yam RX-A810 Aventage
Yam RX-V673
Pioneer VSX-922
leaning towards the Aventage at present, but it is any different to the others in a major advatage way? Also intrested in the networking capabilities for music etc & ipad/iphone stuff.
However i am only running monitor audio BR2 fronts & BR centre speaker & Q acoustic 2020 as rears. Monitor audio sub.
Possibly wanting Monitor audio floor standers or the Q acoustic 2050i floorstanders as replacement fronts.
TJ :)
tj27
30
hi folks
just made a call to Yamaha & went through the in's & outs of it all, looks like im going to order the A810 Aventage even though it has no 'airplay' but it does have yamaha's version with the app on the ipad/iphone etc to play the music through that, sorted!
Julian_b
34
Good choice Tj
I have the RX V3067 and use the Yamaha App, running from my iPad - it will either let you stream from your iPad/iPhone - which I have done.
Also, if you go the digital route as I have with a Vortexbox Appliance (a kind of NAS device) it also finds the server options on that through my network so that it controls/plays my flac files at far higher quality too.
Enjoy.....
tj27
30
Thanks for the reply, really looking forward to it being delivered tomorrow!
I currently run m.a br2 fronts and br centre, would i benefit from getting better fronts as it will be used alot in 2 channel stereo for listening to music as well as films etc.
Was thinking about....
B&W 685's
Epos epic2
Or at a really big push and i mean big perhaps the dynaudio dm2/6?
thanks
sta99y
137
B&W 685's
Epos epic2
thanks
dont forget to keep LCR the same brand if possible.
Maybe some MA's floor standers to fit in then move thr BR2 to the rear duty??
tj27
30
Yes would also then change the centre to match at a later date.
At present i have q acoustic2020i in white as rears as it kept the other half happy with them matching the room better!
sta99y
137
ah yes the white ones, are they the discreet coving or skirting speakers?
tj27
30
Compact bookshelf design and we have a bay window behind us which they sit in and are not noticeable unless you look for them peeking from behind the curtains!
tj27
30
ok, A810 delivered! lovely bit of kit, looking forward to getting it set up 8)
regards speakers, just had a good chat with Rick @ Musicraft & he recommends the Monitor Audio RX1's so am going to have a look at them & go from there.
ps cheers for your time Rick, appreciate it :cheers:
sta99y
137
Give you're views on the amp once setup and let us know which speakers you go with.
MA & Yamaha are perfectly matched so ive been told.
Its what I use and I love it.
