- Aug 10, 2019
- 2,556
- 5
- 0
hi,
This looks like a great place to get some much needed advice plus I have always been a great fan of What-hifi.
I recently purchased an amp. and matching speakers to do some outdoor djing for salsa dancing. My present oufit
consists of the following;
Amplifier: Pylepro PT3300
link: http://www.pyleaudio.com/itemdetail.asp?brand=&cat1=Pro%20Audio&cat2=Power%20Amplifiers&model=PT3300
Speakers: Pylepro 700W DJ Speakers
link: http://www.pyleaudio.com/itemdetail.asp?model=PPHP1559
My sources include: Zune MP3 Players, Hercules MK 2 Mixer (coupled to a laptop)
The problem seems to be that I cant seem to drive the system to loud levels and when I try, the music seems distorted.
I know that when i try to use the Fender 150 which is only 150W, they comfortably drive to louder levels. It was suggested
that the problem could be at the pre-amp stage ie. my zune player does not feed enough signal strength to the input of the
power amp. I usually connect to the tuner or tape input of the power amp. However, when i feed it through the mixer, i have more
flexible input volume control and i have pushed the signals to maximum possible and the music distorts.
I am not sure where the problem is and tried to get help from the manufacturers who havent replied yet.
My questions are;
Are the speakers and amp. a good match for the volume of sound that i require to play outdoors to a crowd of 50 people
Do i need a pre-amp?
Is there something in the configuration that is wrong and i can do better?
I purchased the equipment to play to a reasonable sound level, its not that much more sound that i need, probably another 25% loudness and the system would be great for its current use.
Your help is much appreciated.
regards,
Sam
My questions are;
regards,
Sam
