Hi there!
I've aquired some cyrus gear for a bit of a trial and to see if I like it - a Pre-VS2 and X-Power (about £900 all-in S/H). The plan was if i didn't like it to get rid of it on ebay with hopefully not too much loss.
I was using a NAD C352 with b&w CM1 speakers and a Dacmagic. The new cyrus kit sounds more detailed and I can definately hear the x-powers presence ie more low-end power grunt and dynamics which is great. Initially i thought it was amazing but now its all getting a bit fatiguing, a bit "in-yer-face" and slightly harsh. (After only a days listening). In fact its getting on my nerves now and have had to turn it off.
I think I'm missing the warmth of the NAD which I could listen to for hours. I am slightly bemused though because I wouldn't have described my b&w CM1's as harsh/fatiguing (more warm and full sounding). The other thing is that although the prevs2 was well used, the x-power was brand spanking new still in the cellophane etc - could it be that the xpower needs more time? (I am highly skeptical about this). I've also changed to copper speaker cable, and changed the chord cobra 3 to a gotham interconnect (and tried cambridge audio cheap interconnect) but to be honest there is no difference. Not only that but i've fiddled with the phase options on the dacmagic which to be honest I couldn't really tell the difference!?
So is this the CYRUS sound? or could it be the xpower needs time to run in?
I'm a bit gutted actually because at the moment I don't think i'll ever find a system I'm happy with!
Matt
Incidently the reason I got the upgrade bug was that although I really liked the sound of the NAD I found that at times (particularly at low volumes) it was a bit flat and undynamic until you turned the volume up to a bit too high levels for me. The cyrus gear has definately sorted this out but at the expense of almost making my ears bleed (well not quite that much but you get the idea!).
Matt
