I've tried lots of different cables. The only time I ever noticed an audible difference was when using really cheap (think 99p) or really badly made/designed cables.Just out of curiosity Mike, have you ever tried different combinations of cables in sequence and subjected them to your analyses? I'm just wondering whether any mild form of thermoelectric effect is possible with different conductors. I know kit gets warm, and voice coils can be burned out (NOT in!) with too high volume levels. (Because I did it when I was a youngster...)
(I'm certainly not trying to prove any sort of point here - just curious and lacking the equipment to see for myself.)
Me too - I wouldn't suggest it of others without knowing them though.
Let's chalk that one down to experience - hi Trev, hope all is well with you in these troubled times.
I take that statement as meaning it’s an incredibly high price for performing as a safety device! What they probably meant it’s very good performance for the money?Synergistic Research Orange Fuses
But they do have an 'extremely good price/performance ratio'.
Although, AudioQuest were doing demos a few years ago at the Bristol Show, showing the difference between wireless and cabled transmissions.Cables will always make a difference. Unless you listen wirelessly.
There's no such thing as audio fuses. It's more snake oil BS.I have never tried audio fuses, so I’m simply being mean!
A properly made cable shouldn't make any discernible difference.Cables will always make a difference. Unless you listen wirelessly.
and following on from the basic 79 strand speaker cables i/we use and recommend. Here's a picture of second and last speaker cables i/we use and recommend. Basic 500 strand speaker cables chilling out at the store before heading off our clients homes -
Price per metre presumably.may i ask whats the reason for sometimes recommending qed 79strand and other times 500 strand cable ?
The thicker the cable, the lower the resistance. The lower the resistance the better the sound.
I have found, if you're buying most of your kit from one dealer then a bit of haggling can get you speaker cables or an interconnect thrown in...... pretty tricky to do online though...i believe the 500 hundred strand would have a lower impedance compared to the 79 strand hence should work / sound differently as a result ?
looking at the pic of the 500 strand cable i'm guessing that it costs at the most £5 per m ?
(i would expect these cables to be included in the cost of a system purchase or given away free).
may i ask whats the reason for sometimes recommending 79 strand and other times 500 strand cable ?
If basic 500 strand speaker cables are not practical to use for eg. with spring clip terminals then use basic 79 strand speaker cables instead.
2 but a difference is not necessarily an improvementRight - serious question and intended just to see what people think and have experienced - if possible I'd prefer it if people didn't feel the need to put the boot into each others' opinions - I realise that this might be a forlorn hope 🙂 Italics for important emphasis to the statements.
I don't think there's any way of inserting a poll here, but just wonder whether people feel they best fit into these four cat-and-pigeonholes:
1) Cables make no difference whatsoever. As long as the material is a good conductor that's all there is to it - bell wire and freebies are all you need.
2) Cables can sometimes make a difference, sometimes subtle, sometimes less so - but you are highly sceptical of very big price tags.
3) There's always something to be gained from 'better cabling', though the law of diminishing returns applies.
4) Cables are more important than any other aspect of hifi - Russ Andrews/Kimber is a bargain.
FWIW, I am a 2. Not a number 2, mind...
