Many people can still be wondering about what people say about this amplifier. Not sure if this post will help define how good of an amplifier the Fosi Audio V3 is, but it's a bargain I can say!
For not much you can get an audiophile-grade amplifier that is very well-built and is pretty barebones everything that you need in terms of features on an amp. It's very simple and easy to understand how to work it out.
There is one knob that controls the sound output, you have speaker binding posts, and RCA input and the power supply input.
In terms of sound I believe depending on tastes it can sound perfect or decent, I believe that it sounds great, because there is a very good stage and clarity that comes from this thing. I personally compare this amplifier to a setup that throws my setup to the wall in terms of price, but I also say that i personally find my setup better-sounding than the 30 000CA$ pair of speakers that is the reference setup at my local audio shop.
I do not think the amplifier colors the signal very much. I think that it can be paired with anything, though if you don't think the stock amplifier works well with your setup and you want to be like me and fiddle around and change stuff to your liking, the OP-Amps are swappable and you can throw some SparkoS OP-Amps in there even, though I have yet to try this cool feature.
Is the amplifier good? Without doubt.
Does it have good value? Absolutely.
I approve of this Amplifier and this made me absolutely lean towards Fosi Audio if I wish to get good things.
If you have any questions, I will try to be as active as possible on this discussion. Have a good day!
