Mine's far from perfect.Unfortunately my hearing is very dodgy these days, but I’ll see how it goes!
But just the fact that you identified the same general traits as I did on the stereo V3.....that's good enough for me, thanks 👍
in this V3 mono has cured the speaker load dependency issue,
It's said to audibly affect the HF performance, depending on the speaker load.What effect does speaker load dependency have on the listening experience?
*Wouldn't a genuinely blind test be interesting? 🤔
Well that's true (as it is of all hi-fi).The V3 Mono's are not a miracle worker
The fans has a pwm regulator. At the lowest level there is hardly no noise and the amps are cool. Not bulletproof but for now a fine solutionNo doubt the fan does it's cooling job 👍
But, however quiet it may be, it will still be making some noise.
My laptop has had the hard drive swapped for an SSD - to eliminate some noise.
But it's still got a fan - which is why I keep it out of my listening room.
Chances are that people don't hear fans when music's playing - just like you can't hear hiss and low level hum when music is playing.
But, if you can hear it when the music stops....then, like it or not, it's part of your music.
Bottom line for me is that if a fan really was necessary with the V3....it would stop me buying a V3. (OK if the pair were behind the front wall in another room).
I’ve measured mine with a medical thermometer that doubles as a room/item thermometer with a setting option. In our typical 22C ambient room the maximum I’ve measured on the Monos is 39.4C.No doubt the fan does it's cooling job 👍
🙂 No, but it certainly highlights the Fosi value.Best not to say that the RRP of the cables exceed the price of the amps!
Yes it is weird, and they measure about 29C in a 21C room, measured early morning after in standby overnight. As you say, not much in the scheme of things.🙂 No, but it certainly highlights the Fosi value.
I've read about the 10 watt standby consumption. It is somewhat surprising - and I wouldn't have thought there'd be any exemption in auto-sensing cases 🤔.
Still, compared to class A, it's nothing (as I know you know!)
