professorhat
lesmor:Thanks for the reply prof , good suggestion I have the Sony bluetooth remote for my PS3 so will have to check it out unfortunately it is not backlit and as I have a projector I view in the dark.
Okay, good news, the PS3 remote has the Audio button directly under the Eject button so it should be easy to find even in the dark. I just tried it myself with Batman Begins, pressing Audio once changed to the Dolby TrueHD soundtrack (confirmed by pressing Select before I did this to watch Dolby Digital change to Dolby TrueHD in the top corner assuming you are using the old "fat" PS3).
lesmor:Must admit I have recently changed my floorstanders to small @ 80HZ and set my sub to 120HZ as recommended somewhere so that might be the culprit and have only viewed "I am Legend" since then
Mind you the bass wasn't impressive on "Batman Begins" either ,all of my system has been calibrated to 75db inc sub and speaker positions measured with a tape haven't set up with the Yamaha YAPQ at all though
I might have been lacking in volume and find that volume varies enormously from disc to disc , had to really cut back when listening to "Hellboy2" a while back, my system has never made metal to metal crashes sound metallic if that makes sense?
I would definitely have your floorstanders set to Large speakers as they almost certainly can handle the low end stuff and if the bass is not impressive on Batman Begins (which along with The Dark Knight has buckets of low end!) then it certainly sounds like you could do with it. What speaker setup do you have out of interest?
I just re-watched a couple of scenes on my PS3 to ensure it's not just because I'm using the Sony BDP-S550 as my normal player these days and I can verify it's still sounds pretty damn fantastic to me! Watching the scene where Batman races Rachel back to the Batcave - my subwoofer rumbles the whole room as the Batmobile starts up! Also, the scene on the train at the end is thrilling sound wise and has left me wanting to watch the whole film again!
As you say though, the volume seems to be low - I did have to crank the soundtrack up to a very high volume level on my amp (about -3.5 dB as opposed to -10 dB to -15 dB which I use on most soundtracks when watching through my Sony), so this is worth doing as well to really appreciate the dynamics of the soundtrack.
