The Statmat CDi Blue (from Russ Andrews)
jase fox
212
You place this mat on top of your CDs/DVDs whilst playing them & it supposed to reduce static thats created whilst playing them thus improving both PQ & AQ?
Has anyone had any experience with one? And if so, does it improve the performance?
jase fox:You place this mat on top of your CDs/DVDs whilst playing them & it supposed to reduce static thats created whilst playing them thus improving both PQ & AQ? Has anyone had any experience with one? And if so, does it improve the performance?I did a google and there are some people who claim they can tell the difference, although one did also suggest colouring the edges of your CDs with a black marker pen was more effective.
Wow - that's £40.00!!! Not exactly cheap, by any measure of the word!
i think russ andrews should just design a super power treated helmet , that would improve your eyesight and hearing , like this one...
you could do away with all the other chords , everything would look and sound better , food may even taste better ??
Or these?
http://www.russandrews.com/product.asp?lookup=1&region=UK&currency=GBP&pf_id=4227&customer_id=PAA2310018410080HJYRFIZWWSXGRVXG
Nonsense of the highest order in my opinion. Would be very interested to hear if anyone has actually bought these and heard a difference.
Quite so.
However, I've just invented a polarising magnetometer, which helps to re-orient the magnetic field throughput that all speaker cables generate. Of course, as is well known (by me), magnetic field anomalies add unwanted noise and colourisation to any transported signal - adding significantly to interference at the speaker end. My polarising magnetometer (or PolarMag, to give it its' scientific/sales name) helps to re-order these fields, ensuring that the electrical signal travelling down the speaker cable travels along the path of least resistance, and thus reduces colourisation.
To gain the maximum benefit from the PolarMag, I suggest you place them at 1m intervals along the length of your speaker cables, and having done that, sit back and revel in the improvements in clarity, purity, national balance of payments and world peace consequently generated!!! As recommended by leading experts you've never heard of!!!! Available in packs of 4 for just £99.99, or in special offer sets of 10 for just £299.99, take YOUR system to the next level!!!
I got a hold of one pretty cheap years ago. Made no difference to my setup back then and as it once got trapped in my cd player ive no intentions of ever trying again either
