The Car Thread.
Page 18 - Seeking answers? Join the What HiFi community: the world's leading independent guide to buying and owning hi-fi and home entertainment products.
JDL
907
610
1,770
All sorted ages ago. The insurance company (the Alfa specialist, not the one I use) wanted to scrap my car, but my specialist emphasised the rarity and condition of my car. If it was a rusty old banger it would be a different story.
As the spray was carried outside by a separate coachworks, I kept drumming into my specialist "do not go by the paint code, I want it 'time worn' like the rest of the car". They produced a pretty good job.
I repaired a dent in my Chrysler. I did a decent job but, (BUT!!), I bought the paint using the code and it doesn't match at all. Ha ha. We live and learn huh....
Reactions: DougK1
Yup, that's the problem. You could go to a auto paint specialist with a sample of your existing paint and use a digital thingy which gives as close as possible to the original paint mix.
There was no way I wanted 2024 paint matched to 2005 paint. It would stick out like a carrot in a omelette 😋
JDL
907
610
1,770
Can you take the car if you haven't got a sample?
Recently had a couple of small bits of corrosion attended to by a local one man band - absolutely flawless job. Had seen his work before though - not sure I'd have found it as easy to trust otherwise.
Some are really good, others can be less than.
This colour I had matched was for a bloke in the village, who's got a 1994 Ford Fiesta 1.3. I carried out a few small jobs, incl the paint around the scuttles and replacing his number plates and resetting the tappets. It was quite a satisfying job. I wouldn't say the paint job was flawless but from 20 feet away you couldn't tell the difference between the old and new.
What you need to do a really good spray job: wet and dry paper, microfiber cloth, primer, tak cloth**, paper and masking tape, matching colour match rattle can** and a tin of clear lacquer.
** Not available from Halfords.
DougK1
649
964
1,770
Halfords are good if you want a rattle can with the original paint code. But older cars have faded paintwork. I'd rather spend a little more and get the exact colour match.
Of course you needed an exact colour match, I would if I had a car as rare as yours. Mine is just a method of transport for me, a way to get from A to B. Apart from tin-worm and minor electrical issues it has been incredibly reliable and long may it continue. I doubt my next car will be as dependable so I'll try and keep this one going as long as possible.
Reactions: JDL and Gray
Yeah, tin worm is a blight with most steel cars. I've had mine fastidiously underseal and - touch wood - it's been clear of any nasty grot, fairly unusual for these 156s, especially as its never been garaged.
Your car sounds ideal for your daily needs.
Thanks for that. It doesn't feel desperately useful to me:
- Cars like Ferrari and McLaren will tend to have smaller mileages than mainstream stuff - so it might actually be that they last as long in years between needing a repair than more mainstream stuff. Ditto repair costs are going to be higher because the base cost of everything in such a car is higher.
- Work needing doing doesn't necessarily mean reliability to my way of thinking. Reliability is your car not working - there's no data about whether these were those sort of faults.
I suspect stuff from What Car? is probably more informative - not that I read it.
Direct link to the original site:
None of those are on the 10 in the video.
Audi, BMW, Tesla and Range Rover/Land Rover don't come out too well. The only Italian car on the list is Maserati Levante.
The one you've shown is from 2020.
Friesiansam
That’s the only unreliability list on the Warrantywise website, as far as I can see, there is, however a 2024 reliabilty list. Like 12th said, not the most useful.
BTW, I also don’t watch Carwow videos, presenters are much too annoying.
I didn't post the vid because they annoying or not, thought it's a credible alternative to the common consensus. Several German cars, two Musky cars, Range Rovers.
It's a bit more interesting than the average car review you often find in a sea unknown herberts.
Friesiansam
I watch VERY few reviews of anything on YouTube. Better things to do than searching through a giant, festering haystack, to find the very few shiny needles...
Reactions: DougK1
