The £2k Amplifier question.
A mate has asked me to help him source the best Integrated amp he can get within the budget of two grand .
he has a Gyro se, moon CD player and kef reference speakers.
an integral phono stage of good quality is a must.
what would be good amps to try out, either new or 2nd hand.?
dim_span
13
CnoEvil said:
dim_span said:
Good shout but doesn't have a built in phono stage.
http://gadgetynews.com/musical-fidelity-m6si-integrated-amp-review/
snip:
When I decided it was time to spin some black plastic on my Pro-ject Xpression through the M6si’s phono stage, that’s when things got interesting. The phono stage is switchable between MM and MC, just in case you were wondering.
I am good lad and had read that the new amp is equipped with a very accurate RIAA, within ± 0.5dB from 20 Hz to 20 kHz. I was also aware that it maintains its accuracy right up to 50 kHz.
That might mean a great deal to some of you and you should probably be suitably impressed
CnoEvil
556
14
dim_span said:
snip:
The new "Si" version is a different model to the one you linked to (which I believe doesn't have a phono stage).
CnoEvil
556
14
dim_span said:
eek .... sorry ... I see that some guys use a musical fidelity V-LPSII connected to the M6i for the phono
It's still a great choice provided a separate phono stage isn't out of the question.
lindsayt
16
http://www.ebay.de/itm/Accuphase-E-303-Integrated-Amp-TOP-RARE-/151458783970?pt=DE_Elektronik_Computer_TV_Video_Elektronik_Verst%C3%A4rker&hash=item2343a5a2e2
http://www.ebay.de/itm/PREAMP-AMPLIFIER-DENON-POA1001-PRA1001-PERFECT-CONDITION-/181651830313?pt=DE_Elektronik_Computer_TV_Video_Elektronik_Verst%C3%A4rker&hash=item2a4b4af629
http://www.ebay.de/itm/Sony-TA-F870ES-Amplifier-Verstarker-Top-Zustand-FB-remote-works-100-/311248723498?pt=DE_Elektronik_Computer_TV_Video_Elektronik_Verst%C3%A4rker&hash=item4877de9e2a
rainsoothe
lindsayt said:
hey, OP
This Accuphase looks like a really good deal - and, well basically, most of the 2nd hand suggestions everyone posted so far. If you can return these (in case your friend won't like them), and they have warranty, such a purchase should be safe, and they should sound really awesome. On the website from this bay add there's more stuff that might peak your interest, like the Kenwood L-A1, which seems to be in the ballpark (@2600 euro).
If you want new, most amps near that price mark won't have an integrated phono stage. The Creek Destiny 2 is a sound suggestion, to which you could add Rega Elicit-R (both of these have phono stages).
Also, if a separate phono stage is an option, you could look at one of these (cheap to expensive): Graham Slee Gram Amp 2 SE, Musical Surroundings Phonomena II (this one seems to be somewhat of a bargain), Clearaudio Basic + or a Sutherland PH3D phono stages. As for a NEW amp to go with the respective phonostage, I auditioned most of these with a Simaudio Moon CDP or DAC and they sounded great together: Simaudio Moon Neo 250i (which is the obvious partner), Naim Nait XS2, Sugden A21SE and Jadis Orchestra (tube amp, sounds fantastic). Also, Primare I32 might be worth checking.
goodluck
lindsayt
16
dim_span, good spot on that Aragon 24k pre-power. I'd be tempted to have a punt on that myself if I wasn't already amplifiered up.
dim_span
13
bigfish786 said:
Thanks.
for all the responses and ideas.. We will wade through them all.
of the used items, examples given were just some of the possibilities based on current listings on ebay
be patient and do your research .... £2k will get you something really good especially on the used market
CnoEvil
556
14
bigfish786 said:
Having had my leema amp a while now, I did mention to my mate that the leema amps are very good, and well respected.
I found a leema Tucana II for £1899 which I think is a bargain.
It will probably take something of that quality to do justice to the Kef Refs.
