Hello all,
Im hoping that some one who has listened to both of the above can give me the benefit of some their experience.
Have recently had a demo with the B&W 684 (683 too big). While overall I suppose it was OK, there was no real WOW factor. While I realise that £700 is'nt a massive amount for a speaker (relatively speaking), I was probably expecting a bit more
I'm not sure if there is a technical term for this but at lower volumes they sounded muffled. The volume at which it started to sound good was really TOO loud. Also, again I'm not technical, there were some aspects of the sound in the high end that they seemed to cut short/struggle with/understate.
Have been looking at the Tannoy DC4T (a bit more expensive but still within overall budget at a push) but I can't get a demo locally. From a style point of view these would probably first on the list. Has anyone heard these? if so how do they compare with the 684 as a point of reference? Can I expect better detail at lower volumes. What does it do well? What drawbacks do they have?
Will ultimately be using the fronts I choose as the basis of a 5.1 system from the same manufacturer. I'm thinking that if I get stereo speakers sorted first then everything else should fall into place... hopefully!.... but music is important!
Many thanks
Many thanks
