davedotco
Overdose said:davedotco said:This whole 'reference system' thing is, to me, just plain wrong.
The only reference is a real live performance, real music, real musicians, real world.
I don't understand how you can put any context into a review if you have no reference equipment. Without a baseline of some sort for comparison, reviews would seem even more spurious between reviewres and be less relevant.
What better way to test a speaker than to drive it effortlessly with a quality amplifier? Using anything less would compromise the potential of the speaker and give a false indication of its abilities. The same applies to any equipment.
As for real, music musicians, performances etc. for most types of music, performances are amped over PA systems and are not any reference that I'd want to emulate.
As I said above, the trick is listening to the music not the sound that it makes. There are plenty of good recording that can be used, that capture the 'feel', the 'prescence' of a live/real event and I find these invaluable.
I find that listening in this way helps tremendously and can often take crude variables, like a bright or boomy dem room, pretty much out of the equation. I appreciate that this is not normally how most people listen but it works for me.
A simple example, I often played a track that had a lenghty acoustic guitar into, on most systems it sounded crisp and clear and on the better ones so clear and pricise that I felt that even my extremely amaturish playing skills would be able to pick out the notes and play the tune.
Then on this particular ocasion I changed the amplifier and suddenly I knew, I just knew that I could practice for the rest of my life and never come close to the superbly expressive and emotive playing of the artist. The new system just made the music so much more real, the talent of the artist so much more evident, the sound had not changed one jot, but the music had.
Anyway I know I am not going to change your views on this but I thought an explanation worthwhile, a different (from the norm on here) way of doing things that has served me well.
