suggestions on a new/second hand pair of floorstanders..
Rowan1981
Hi I currently have a pair of Q acoustic's 2020i's powered by a Marantz pm5005 and would like to upgrade to a bigger pair of speakers (floorstanders) as my room is fairly large 35 sqm I would like to be able to fill the room up with sound. so I was wondering what floorstanders people would recommend on a budget of around 300 GBP ? (I dont mind mind buying second hand )
My music taste is vary varied, anyhting from Blues, Rock, Reggae, a bit of jazz and, 70-80's rock.
I like warm sounding speakers with good detail in the highs.
any suggestions would be great as I can then go to try and demo the suggested speakers.
lindsayt
16
For that budget and that sized room I'd be looking for 1970's Japanese JBL homage speakers from the top of the range from the likes of Akai, Panasonic and Sansui. I'd also keep my eye out for big old American horns / horn hybrids.
Rowan1981
These Tannoys look gorgeous! I guess these are upgraded models from the V4's ?
It would be interesting to know if my Marantz pm5005 will power these sufficiently...
Rowan1981
Thank's for your suggestions - I will keep my eye out for some over the coming few feeks.
I also recntly discovered these http://www.whathifi.com/jbl/studio-530/review
found a local dealer that sells them for around 550 gbp. bit out of my budget but maybe worth saving for ?
ASK THE COMMUNITY
